Lost/broke my Autometer boost gauge hose...Any alternatives, a fix?
I have an Autometer boost gauge that has had a broken (original) hard plastic hose. Where can I find a replacement or are there other alternatives. I read on old threads that I can just use a certain vacuum hose or I can find replacements at my local auto store (autozone, kragen, etc). Thank you for your help!
- NightRider-gsR
- NightRider-gsR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E »</TD></TR><TR><TD CLASS="quote">Yeah, Advanced Auto sells complete boost/vac gauge tubing replacement kits.</TD></TR></TABLE>
Good to know.
Good to know.
If your in Chicago you can pick up my line its brand new I never used it with the BG.
I use a stainless -4 line with fittings on mine worked great no issues
I bought 1/8"NPT to 1/4" hose fittings that I will connect on the back of the Boost gauge and from the T I have off the brake booster line. I bought the wrong vacuumm hose though. (got everything fro PepBoys) but will check out Kragen or AutoZone for Vacuum hoses.
The bigges hoses shouldn't have any effect on the vacuum right?
Autozone sells the replacement clear line for the boost gauges and it comes with fittings. It bought it like 100 times, its there.
Whaaaaaaat? If you can point me to the website where I can purchase it, I'll return all this PepBoys stuff.
EDIT: Found some from here:
http://www.prostreetonline.com...s.asp
Is that it?
Is that it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">Is it the right part?</TD></TR></TABLE>
3222
Yeah the first product. Seriously would use vaccum hose myself.
3222
Well I bought all the fittings...everything came out to about $12 but the hose I bought is wrong so if I return it, it would be around $8+... I should just keep it then huh and run 1/4" ID vacuum hose instead of spending money on the Autometer replacement. $6+ shipping.
BTW mcmaster.com sells that nylon tube in white as well as BLACK... looks much nicer if you have a black engine bay like mine.
i hate that nylon crap. ill use it only about 6" out from the back of the gauge, then use some 1/8" black regular vacuum hose. i slip it over the nylon a few inches and use 2 small zip ties to hold it tight. no issues up to 20 psi
Who is Mr Robot?
a 7 year old thread?!?
don't most know to put a nipple on the gauge and use rubber or silicone hose to supply a pressure signal to the gauge?
it's universally know that white hard tube is ****
Civiclx
Mar 14, 2004 12:46 PM
Civiclx
Nov 18, 2003 09:29 PM
