EK - OBD1 B-series swap experts needed!
Old Jul 23, 2007 | 01:34 PM
jdm_vtec's Avatar
Default EK - OBD1 B-series swap experts needed!
description:
96 ex civic
OBD0 B16A head (GSR cams, titanium springs & retainers)
OBD0 B16A intake manifold w/ blocked off FIV
OBD2 B18C5 throttle body (port matched)
OBD1 B16A (built) block
Ok, a few questions for the gurus..
first off, which throttle cable do I use? stock d16y8? 92 GSR?
I was told to use 94-01 Integra or 99-00 Si A/C bracket, I thought Del Sol VTEC was required.. which is it?
on the FAQ it says "use the left side (driver side) dual-post engine block mount (only needed if going B18C)", So I don't need one for the B16A? use stock?
lastly, since the block was updated to OBD1, the nipple for my IACV to run back into the coolant system is gone, so I have a hose from the water pipe into the IACV, then i'm running it back to the old FIV nipple shown in this pic.. will this work ok?
Old Jul 23, 2007 | 02:07 PM
jdm_vtec's Avatar
Old Jul 23, 2007 | 02:16 PM
slowcivic2k's Avatar
Default Re: EK - OBD1 B-series swap experts needed! (jdm_vtec)
Use the factory cable, you will have to modify the bracket to hold the cable though.
If you had a D series in there with a D series compressor, use the Del Sol VTEC mount, or one from a B20 CRV, this is what I did since I did not have an Si pump, nor did I want to drain my A/C.
The mount that came with the engine should be fine, the GSR had a mount similar to the transmission mount on the timing belt side, as did the 92-95 civics, in 96-00 they used a oil filled mount. If the bracket on the motor has one bolt hole, it will fit.
This should explain the coolant portion of it:
Old Jul 23, 2007 | 02:44 PM
jdm_vtec's Avatar
why thank you sir.
jtaylor16
Aug 19, 2012 01:02 PM
mynameizstitch
Jan 26, 2010 06:11 AM
PostSRT
Oct 5, 2007 04:01 PM
Kevinarich
Aug 15, 2006 05:07 PM
2camsaam
Sep 12, 2003 08:20 PM
