DA Turbo
Im installing a turbo onto my da do i have to drill a hole in my oil pan or can i just use a "T" on a oil line that is already there on the car. Cause i really dont want to drill a hole unless i have too. anything would help thx guys.
ive made some threads like this in the past so ill help u out....lol.
U need to do both, U need an oil feed line and an oil return. the oil needs to flow through the turbo so you will "t" the oil sending unit and run that to the turbo, and the oil needs to go to the oil pan after, so u will have to drill it.
U should do some reading about how to install a turbo on a honda, because i dont want you to mess up your car. goodluck with your project.
