integra type r cluster help
Old Jul 18, 2007 | 08:12 AM
ek4shizzle's Avatar
Default integra type r cluster help
/thread
Modified by ek4shizzle at 10:22 PM 10/13/2007
Old Jul 18, 2007 | 08:34 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: integra type r cluster help (ek4shizzle)
what year itr is the cluster going into?
Old Jul 18, 2007 | 08:41 AM
ek4shizzle's Avatar
Default Re: integra type r cluster help (wrx-killer-Sti-eater)
my 94 rs
Old Jul 18, 2007 | 09:20 AM
ek4shizzle's Avatar
can someone please answer this question real fast? thanks
Old Jul 18, 2007 | 09:59 AM
coolhandluke's Avatar
This may sound lame, but have you checked your dimmer switch? Make sure it is turned up- cheap suggestion.
On another dimmer note, shortly after picking up my 99' gs-r in 04' I had to replace my dimmer switch because it dimmed over the first two months of ownership. It eventually did not light up anything, so I replaced the dimmer switch which solved my problem.
On the cluster side, are you positive the illumination bulbs are factory? 3rd party bulbs tend to be dimmer, and do not last as long.
Old Jul 18, 2007 | 11:09 AM
Default Re: integra type r cluster help (coolhandluke)
^^^^ true, on the clusster the cluster the red/blk trace wire is standered on the itr and teg harness. The dash harness is the same. I would check to make sure the plastic connector is making good contact. Also check out that dimmer switch
Old Jul 18, 2007 | 01:10 PM
ek4shizzle's Avatar
thanks guys, but all the bulbs are good. i even switched out all the bulbs and mixed them up in the back(there are 3). but its always the same side that gets dim(right side where the speedo and fuel gauges are). and yes i already checked the dimmer switch it is turned all the way up, but i havent tried replacing it. even my climate control looks normal( i ambered those too). my recent LS cluster was fine. i also took apart the whole type r cluster and cleaned off the clear, plastic reflectors inside(it was dirty) and it did get a little brighter, but overall does not match. the tachometer is really bright tho.
Old Jul 18, 2007 | 02:47 PM
Comp97GSR's Avatar
I suppose somebody could have taken the gauge face off at one point and got the backside is dirty.
Old Jul 18, 2007 | 04:50 PM
94rs-turbo's Avatar
that area doesnt get a much light but try replacing the bulbs and cleaning the area
Old Jul 19, 2007 | 01:45 AM
ek4shizzle's Avatar
Default Re: (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">that area doesnt get a much light but try replacing the bulbs and cleaning the area</TD></TR></TABLE>
already replaced the bulbs and cleaned everything inside and out, front and back. still lightly dim. i just want to know if everyone else's cluster is like this or is it just mine
Kevin_Ceee
Oct 25, 2012 08:48 AM
b18c1del
Aug 22, 2009 01:25 PM
xxjasonxx
Nov 20, 2008 06:08 PM
Frstyl838
Apr 25, 2008 07:35 AM
