Cluster in my 99 civic.
The cluster light in my civic won't work anymore yet the indicator lights still do. It worked before. I changed the bulb for my cluster and I also changed the fuse.. I dont know what the problem is.. anyone help?
Re: Cluster in my 99 civic.
Did you convert to leds? Try flipping the bulbs 180 degrees. Sometimes there just not in there incorrectly and won't light it up. What bulbs did you use to replace?
it is prolly your dimmer switch. take out the switch and run a test light on the wire to the switch. if you are getting power to the switch then it is prolly the switch. to test and make sure it is not the bulbs like they said run a jumper wire and see if they come on for a sec. if you dont have power to your switch tho than it may be a fuse.
