Bad idle, Tryed a million things
Old Jul 17, 2007 | 05:31 PM
b16a4's Avatar
Default Bad idle, Tryed a million things
Hey guys/Gals....
One day i was driving home, and my outer CV Joint just snaps out of place, the bearings just separated. So i replaced the cv joint and attempted to start the motor. Wont turn over. The motor haven't enough compression to start..
The timing had jumped. Set back the timing and started up the car. Started. Now heres the sweet part.... I just don't get a steady idle. My fuel gauge also fluctuates with the erratic idle.
I tryed a working ICAV, Cleaned Tb/Intake Manifold. Cleaned Gas Tank, Blew out Fuel Lines, Changed Fuel Filter, New jvc plug Wires.
Can anyone point me in the right direction?
Old Jul 17, 2007 | 05:54 PM
bluelxfodo's Avatar
adjut the valve under the trottle body
Old Jul 17, 2007 | 05:58 PM
b16a4's Avatar
Default Re: (bluelxfodo)
i dont think i have one of those
Old Jul 17, 2007 | 08:53 PM
akunamatta's Avatar
* B A N N E D *
double check the timing... electrical included, then perform a compression test and see if u bent something inside.
Old Jul 18, 2007 | 03:49 PM
b16a4's Avatar
Default Re: (akunamatta)
Thanks for the response,
Compression was 180 across the board.
Old Jul 18, 2007 | 03:52 PM
lmananT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think i have one of those</TD></TR></TABLE>
he means the FITV which is bolted under your throttle body. here's a how-to article on it:
http://www.team-integra.net/se...=1167
Old Jul 18, 2007 | 10:38 PM
Mista Bone's Avatar
D Tranny Guru
grounding issue, the moving fuel gauge is the give away
Old Jul 18, 2007 | 11:53 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
hey with the idle problem i had the same prob found out i had wrong intake manifold gasket and thats why the idle was going up and down or ur IM gasket is jacked up
Old Jul 19, 2007 | 02:30 PM
b16a4's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">grounding issue, the moving fuel gauge is the give away </TD></TR></TABLE>
thanks for the response, what do i check to see whats not grounded?
Old Jul 21, 2007 | 11:37 AM
b16a4's Avatar
Default Re: (b16a4)
Could a blown head gasket cause this?
Old Jul 29, 2007 | 01:16 PM
b16a4's Avatar
Default Re: (b16a4)
BYPASSED coolant lines under TB and IACV. Compression is 180 180 180 180.
What else can i check guys
TheDeadAreBack
Feb 11, 2013 10:56 AM
jdmkid209
Aug 18, 2010 06:56 AM
memorybox
May 13, 2009 01:01 PM
hedtrip
Jan 22, 2008 05:43 PM
b16a4
Sep 12, 2007 06:02 PM
