i have a h22a eg need help
i have a 1992 civic hatchback with an h22a motor in it and im having some problems with it. the car use to drive fine no problems what so ever but now its not doing so good. sometimes i can start the car but other times i cant.....when i turn the key it doesnt even make a sound. i have to push start the car most of the time and when i drive it i cant turn it off or it wont turn back on again. does anybody have an idea what it might be
i would check ur ignition switch dat sounds like ur prob and get someone to turn the switch 2 make sure u are geting fire to the starter if it doesnt then dats ur prob
my car used to be that i would have to pop start it so go anywhere, it was my battery was bad, it didnt hold charge i got a new one for $60 w/ 1 yr warrenty
Who did the swap? WHen they extended the alternator wires did they solder and heat shrink? If not check em all to make sure there is no loose or faulty connections. Sounds to me the wire job was junk and your alternator isnt charging... from my eg h22 experience thats the first thing i would check.
