Hey who has balanced there rods / pistons / crack etc..
Old Jun 8, 2002 | 02:29 AM
BLKCRX's Avatar
Default Hey who has balanced there rods / pistons / crack etc..
Hey all I have the chance to Balance my JE pistons / Eagle Rods / stock b16a2 crank and a few other internal parts.. of my engine.. who thinks its worth it.. I got quoted 250$ (us) which I think is resalable.. iv neva seen much balance talk within our FI engines..
Regards James
Old Jun 8, 2002 | 07:20 AM
93LSivic's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (BLKCRX)
If you get this done, make sure you have the crank pulley, flywheel and clutch balanced as an assembly too. Without those, balancing is pointless.
I would say go for it. Im trying to remember last time I had built a motor what the going price was............then again that was about 6 years ago, so who knows now.
Old Jun 8, 2002 | 04:41 PM
BLKCRX's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (93LSivic)
Thanks man ill make sure i get those done also...
Regards James
Old Jun 8, 2002 | 05:07 PM
BROOD's Avatar
Yes, it is worth it.
everything: crank, rods, rod bearings, rings, pistons, piston pins, pin locks, crank pulley, flywheel, clutch assembly
Old Jun 8, 2002 | 07:45 PM
Turbo Laser's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (SLPR)
Is balancing necessary for a complete rebuild and what exactly does the machinist do when he's balancing your engine?
Old Jun 8, 2002 | 08:30 PM
Ltech's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (NOCARLOSER)
A friend of mine doing it for $50. It's good to know people
jason phan
Old Jun 8, 2002 | 10:42 PM
Flamenco-T's Avatar
to check for clearances and tolerances in between internal moving parts...
be sure they know what they're doing...I'd rather pay more but have a peace of mind, than trying to be cheap and get screwed in the end...god knows we all have been there before...
Old Jun 8, 2002 | 10:46 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Hey who has balanced there rods / pistons / crack etc.. (Ltech)
jason phan
who is..
art
Old Jun 8, 2002 | 10:56 PM
accordfreak's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (Arturbo)
if you get new sleeve, bore 2mm over, rods, pistons, rings, and replace everything else with new stock parts, is it necessary to blance your whole engine or would your engine would not run good?
Old Jun 9, 2002 | 12:16 AM
VaporTrail's Avatar
New User
i have not been able to balance my crack, the addiction is too strong, sometimes I mix it with crank and smack for that extra boost, but you have to have a built bottom end for that. I would highly recommend trying to balance a bean pole in your crack, as thats usually what's easiest. Clench hard and it shouldn't be a problem, good luck
Old Jun 9, 2002 | 07:09 AM
Ltech's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (VaporTrail)
This guy name william. He work at a machine shop by Town East Mall. They built the motor for Kenny Tran.
Old Jun 9, 2002 | 07:38 AM
Sonny's Avatar
LOL
Sonny
Old Jun 9, 2002 | 07:42 AM
b18bturbo's Avatar
Kenny doesnt get motor work at performance auto supply anymore if thats what you are talking about. There clearances were way off and finally kenny got fed up. He blocks he uses now are from rs motorworks in cali or aebs. The internal parts are all done by tony and kenny themselves.
Old Jun 9, 2002 | 08:30 AM
turboex's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (b18bturbo)
spendy. i got my clutch to pully and everything between balanced for 100bucks.
[Modified by turboex, 5:31 PM 6/9/2002]
Old Jun 9, 2002 | 03:15 PM
BLKCRX's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (turboex)
well thanks for all the extra info guys..im going to get another qoute for blancing the rest of all the moving parts in my engine.. ! makinng sure they do what's been talked about above.. and ill make sure they measure eveything to the higest cleanance. ( i just hope they know how to caculate that.. bc i have no idea ) but then again im studing med.. lol not engine rebuilds.. eheh
Regards James
Old Jun 9, 2002 | 03:23 PM
int3gra's Avatar
BLKCRX, buy the Helms manual and u can learn to do it yourself.....read it during biology class. this is your new hobby, disecting engines not people/animals.
Old Jun 9, 2002 | 07:19 PM
Ltech's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (int3gra)
William told me Kenny trying to low ball on these guys and told them that he can get it done somewhere in cali for a cheaper price. That is what william told me last weekend when we hung out together. I don't care the price I've spend 15g on the crx so far and I'm not going to save money for some poor quality job. Where do you get your stuff done?
jason phan
Old Jun 9, 2002 | 08:08 PM
88CRXHybrid's Avatar
$160 for a complete balance job down here in Mississippi
Old Jun 9, 2002 | 10:34 PM
BLKCRX's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (88CRXHybrid)
i wish i could buy a Helms manual out here in Australia... and or.. i wish somone would scan this lovly book, that i hear so much about !!!
and or i wish they had a digital copy.. so ppl like me could buy it. !
PS anyone feel like scanning a lot of pages ! ehhe
Regards James
Old Jun 10, 2002 | 03:24 AM
sparkz's Avatar
http://www.helminc.com
any helms manual youd like
Old Jun 10, 2002 | 06:26 AM
X2BOARD's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (sparkz)
Get the entire assembly balanced.... although Honda stuff is pretty well balanced, it's not high speed balanced... You will feel as thought the car is smoother on acceleration and up top. Get pistons, rods, crank, flywheel, Pressure Plate, crank pulley $250 sounds expensive.
X2
Old Jun 10, 2002 | 03:27 PM
BLKCRX's Avatar
Default Re: Hey who has balanced there rods / pistons / crack etc.. (X2BOARD)
Hey all i just had another quote.. to balance my whole engine !
which includes pistons rods crank pully flywheel pressure plate and a few other things for 159.50$ ( aust ) so thats like 75$us ! yeepie now im very happy !
Thanks guys for ya help ! it pays to shop around ! i so can't wait to get this engine put back together !
Regards James
jdm_special
Engine Machining & Assembly
May 11, 2019 11:17 PM
CHU-JDM-DC2
Feb 1, 2016 12:52 PM
euclid
10
Dec 21, 2004 05:46 PM
Propulsion
Nov 26, 2003 06:54 AM
shingles
Nov 21, 2001 02:46 PM
