Irratic Idle B16
Old Jul 8, 2007 | 04:51 PM
Ep1dem1c's Avatar
Default Irratic Idle B16
Irratic Idle in my B16 after installing the following:
Skunk2 Intake Manifold
Skunk2 TB
all gaskets changed.
all lines hooked up correctly
all electrical plugs hooked up correctly
NO CEL
Idle jumps from 1300-2100 back and fourth constantly
Could it be the TPS?
Also i think since the erratic idleing is so severe it may have messed one of my motor mounts up because i can feel movement very bad in my shifter
Old Jul 8, 2007 | 05:01 PM
forcefedferio's Avatar
Default Re: Irratic Idle B16 (Ep1dem1c)
had the same problem when i put my skunk2 manifold and TB on, it was the gasket between the head and manifold leaking, i must've missed part of the old gasket cleaning it off. try cleaning the gasket surface up again and i've also read that a heatshield gasket like the Hondata one also fixes alot of people's problems with this issue with skunk2 manifolds. hope that helps.
Old Jul 8, 2007 | 07:55 PM
Ep1dem1c's Avatar
Default Re: Irratic Idle B16 (forcefedferio)
thanks ill try that out tomorrow
IlIkEg's
Mar 22, 2006 06:55 PM
DriveSlowHomie
Mar 29, 2005 10:08 PM
THEO-Vtec
17
Jan 21, 2005 07:55 PM
Tofurky
Sep 11, 2003 06:42 AM
Tofurky
Sep 11, 2003 02:52 AM
