GSR IM Gasket on Skunk2 Manifold= Vacuum Leak?
Has anybody else tried this? Did it result in a surging idle? Also if i elimnated the coolant lines from the IACV would it cause RPM's to surge? I'm talking bouncing to 3.5K Consistently.
Re: GSR IM Gasket on Skunk2 Manifold= Vacuum Leak? (IlIkEg's)
i have a skunk2 with gsr gasket there was no leak. it sound like you have a vacuum leak some where. are your vacuum hoses all hooked up correctly?
Re: (IlIkEg's)
I changed my TB Gasket which was ripped...but still no improvement. Also...when i disconnect the IACV while the car is running the idle changes. Could my IACV be bad? The only other thing i could think of would be the Intake Manifold Gasket not seated right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IlIkEg’s »</TD></TR><TR><TD CLASS="quote">Has anybody else tried this? Did it result in a surging idle? Also if i elimnated the coolant lines from the IACV would it cause RPM's to surge? I'm talking bouncing to 3.5K Consistently.</TD></TR></TABLE>
does it jump when you first start it or does it only jump after its warm?
Re: GSR IM Gasket on Skunk2 Manifold= Vacuum Leak? (e gee two)
Problem fixed!!! Thanx for tryin to help. It was my FITV after all. If you are having a similiar problem on your OBD1 car i suggest you check this and make sure its screwed in and clean.
Civic98KH
04-25-2007 08:32 AM
aalb1
10
04-19-2005 07:32 AM
