Car wont star after swap!!!!HELP ASAP!!!!!!
Old Jul 8, 2007 | 04:10 PM
1BADEGDC2's Avatar
Default Car wont star after swap!!!!HELP ASAP!!!!!!
We did a type r swap into a 93 civic cx, the typre came from a em1 obd2b, we got the obd harness and swapped everythin. When we go to start the car everything sounds good but the cars not pushin out fuel. Why is it not!? The car was runnin perfect before we did the swap. We had the stock fuel pump, then put a walbro 255lhp on it. still nohin.
Old Jul 8, 2007 | 04:22 PM
pdiggitydogg's Avatar
fuel pump is overkill...by a lot
get rid of the obd2b ecu and jumper - run a chipped p28 or a stock p30
(You will have so many problems with that obd in that car)
Do you have spark? Fuel?
https://honda-tech.com/zerothread/1922346
Old Jul 8, 2007 | 04:29 PM
1BADEGDC2's Avatar
sorry, the computer in the obd2b em1 had the jumper, it was a obd1 p28 chipped and dyno tuned with hondata, so we used they same ecu,
Old Jul 8, 2007 | 04:30 PM
1BADEGDC2's Avatar
its a p72 ecu!obd1
Old Jul 9, 2007 | 09:01 AM
1BADEGDC2's Avatar
Help guys, i need the car runnin!! Thanks for everythin
Old Jul 9, 2007 | 12:57 PM
did you do anything from that link i posted?
Old Jul 9, 2007 | 08:07 PM
1BADEGDC2's Avatar
yea
Old Jul 9, 2007 | 08:08 PM
1BADEGDC2's Avatar
yea still nothing its not giving gas
Old Jul 10, 2007 | 05:55 PM
Start with pressure - what is it?
Are the injectors plugged in? Do they work at all?
Old Jul 10, 2007 | 06:07 PM
egb16pg's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Start with pressure - what is it?
Are the injectors plugged in? Do they work at all?</TD></TR></TABLE>
x2
check out your main relay.
Old Jul 12, 2007 | 04:26 PM
1BADEGDC2's Avatar
the main relay wasnt grounded. Where is that? so next time we dont gotta pay for that.
Old Jul 12, 2007 | 04:42 PM
egb16pg's Avatar
Default Re: (1BADEGDC2)
go to hondahookup.com and check out their downloadable manuals, to see your diagram.
boostin99em1
Jan 18, 2011 09:28 PM
JDMcivicSiEG6
10
Oct 20, 2008 07:25 PM
boostedcivic24
Mar 22, 2006 08:32 PM
Dr Pooface
Sep 28, 2004 06:09 PM
vtec69
Dec 2, 2002 12:18 PM
