smoke from radiator cap please help
Old Jul 3, 2007 | 04:07 PM
Frost_1097's Avatar
Default smoke from radiator cap please help
93 honda del sol d16z6 vtec. after driving there is a lot of smoke or steam coming from the radiator cap. anyone know what's going on?
Old Jul 3, 2007 | 04:23 PM
97Ej6mike's Avatar
Is it secured down good? Is your car running at normal operating temp? Are you too low/overfilled on fluid?
Old Jul 3, 2007 | 05:05 PM
SL!M's Avatar
The cap must be bad. Because of the temperature and pressure, there will be "smoke" which is actually steam, but anywho. Make sure the cap is on alllll the way, and then try replacing it. Cheap fix.
Old Jul 3, 2007 | 05:41 PM
Vt3c_eg's Avatar
Default Re: (SL!M)
if it boils its the your head gasket. it happen to me.have you replace that yet?
Old Jul 3, 2007 | 05:53 PM
SL!M's Avatar
Default Re: (Vt3c_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">if it boils its the your head gasket. it happen to me.have you replace that yet?</TD></TR></TABLE>
yeh but he would overheat all the time from that. I would hope the headgasket is the last step. Its not like changing the gas cap.
Old Jul 3, 2007 | 06:31 PM
forcefedferio's Avatar
Default Re: (SL!M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL!M &raquo;</TD></TR><TR><TD CLASS="quote">The cap must be bad. Because of the temperature and pressure, there will be "smoke" which is actually steam, but anywho. Make sure the cap is on alllll the way, and then try replacing it. Cheap fix.</TD></TR></TABLE>
x2.....$10
Old Jul 3, 2007 | 09:11 PM
civiceg94's Avatar
check where your radiator cap goes onto. on mine it leaks because its chipped a little. and the cap doesn't lock tight. so i have a little antifreeze leaks. which creates the smoke i see. good thing i have a good radiator i just need to replace it.
JDM_SOHC
53
Apr 2, 2009 03:16 AM
YeuEmMaiMai
Oct 1, 2008 07:05 AM
slowassgsr
Jun 4, 2008 03:13 PM
dpkelly
Dec 8, 2006 10:39 AM
gs_rbaby
May 19, 2006 02:08 PM
