d16y7 with vtec dizzy?? Need quick response if at all possible
Old Jul 2, 2007 | 05:26 PM
81CB900C's Avatar
Default d16y7 with vtec dizzy?? Need quick response if at all possible
Doing a y7 swap into a 92 civic. Prior to this the car had a a6 block with vtec head. Will the car work with the current vtec dizzy or do i need to find a non vtec one? Im thinking there is a way for this to work. Any response would be a big help.
Old Jul 2, 2007 | 05:36 PM
81CB900C's Avatar
Default Re: d16y7 with vtec dizzy?? Need quick response if at all possible (81CB900C)
anyone know?
Old Jul 3, 2007 | 05:52 AM
LSVTEC426's Avatar
does anyone know the anwser to this??
Old Jul 3, 2007 | 06:10 AM
speedooo's Avatar
Default Re: d16y7 with vtec dizzy?? Need quick response if at all possible (LSVTEC426)
if its a z6 or z1(vx) dizzy, no. if its a y8/y5, yes.
Old Jul 3, 2007 | 08:03 AM
81CB900C's Avatar
Default Re: d16y7 with vtec dizzy?? Need quick response if at all possible (speedooo)
How would we identify them? I'm sure there's a part number stamped somewhere, yes?
Old Jul 3, 2007 | 03:54 PM
81CB900C's Avatar
... it has two plugs ?
bumped.
Old Jul 3, 2007 | 03:57 PM
Luserkid's Avatar
If it bolts up then your good on that part. But y7 is obd2 and 92 is obd1
Old Jul 3, 2007 | 08:38 PM
81CB900C's Avatar
Default Re: d16y7 with vtec dizzy?? Need quick response if at all possible (Luserkid)
*nods*
It's ok. We found out we're totally fucked on this car anyways. The engine that was in it was a 200+ thousand mi. D16A6 mini-me swap (head of unknown origin, but probably a Y8) that had glitter in the oil... Which probably means it was in the turbo, too... which had a CARDBOARD gasket for the low-pressure oil return line that went into a LOOSE fitting on the oil pan COVERED silicone to keep it from leaking with a BUTCHERED *automatic* wiring harness... Not to mention the inner fender rust that the kid said was fixed at first and so-on and so-forth. . .
walsh22
21
Mar 11, 2007 01:41 PM
Eaglekper0046
Nov 26, 2005 01:11 PM
terminaloverlowd
Aug 26, 2004 07:02 AM
smithbling
May 15, 2003 04:36 AM
