diagnose this problem for me pleasee
Old Jun 28, 2007 | 05:18 PM
boostmee's Avatar
Default diagnose this problem for me pleasee
what are the symptoms of a head gasket or even a cracked head going bad???? for some reason my car drives perfect in traffic but when i go over 65 mph, it starts to over heat, all ready has enough coolant and fans r working
Old Jun 28, 2007 | 05:27 PM
Humble Performance's Avatar
Default Re: diagnose this problem for me pleasee (boostmee)
Which motor do you have ?
Old Jun 29, 2007 | 02:37 AM
boostmee's Avatar
i have a d15b7 with 118k
Old Jun 29, 2007 | 04:05 AM
SOHC IT's Avatar
Either you have a themostat that is going bad, a water pump going bad, or your head gasket is leaking coompression into your cooling system.
Old Jun 29, 2007 | 05:31 AM
92_civic's Avatar
Default Re: diagnose this problem for me pleasee (SOHC IT)
or your radiator is plugged...check the tstat first
Old Jun 29, 2007 | 10:29 AM
boostmee's Avatar
but if it was a leak in my gasket, wouldnt oil mix with my antifreeze resovior, wouldnt their be leaks and wouldnt their be blue or white smoke coming from my exhaust, im not getting any of these symptoms, all that happens is when i exceed 70 mph for 4 minutes my car starts to overheat
Old Jun 29, 2007 | 10:34 AM
devnull's Avatar
waterpump, theromstat or clogged radiator
Old Jun 29, 2007 | 12:07 PM
dtapia's Avatar
Default Re: (devnull)
since your moving down the road at that speed the fans will not come on because of the air flow. so really only leave a couple of problems like a radiator problem or water pump but since it runs cool in town the water pump is the less likley problem and since the radiator depends on air flow to cool down the coolant i would be leaning towards the radiator. check the front of the fins and see if it is covered with bugs and road gunk if so it can be blown out with a air hose and you should see a diffrence.
Old Jun 29, 2007 | 08:58 PM
boostmee's Avatar
i have a simple body kit for my front bumper, could it be possible the bumper would be blocking the air from flowing into the radiator, or is that unlikely
Old Jun 29, 2007 | 10:44 PM
dtapia's Avatar
Default Re: (boostmee)
i really dont think that would be a cuplret unless the front of the radiator is blocked from the body work but i dont think any body kit mfg would be that lame to do that plus it would not be functional.
rudyndrew
Jan 30, 2011 12:48 PM
efjones9
13
Jul 18, 2009 06:14 PM
ZXRider
Honda Civic (2001 - 2005)
Sep 7, 2007 07:55 PM
extrmeboost
Jul 15, 2003 07:42 AM
whagkangmakulet
Sep 23, 2002 08:32 AM
