Need Help On Del Sol
Old Jun 26, 2007 | 02:24 PM
91-lsvtecsi's Avatar
Default Need Help On Del Sol
ok i have a 93 del sol and im havin problems wit trans/clutch area lol the only way to throw car in "R" is to turn the car off.............to throw it in any gear it has to be around 2k-3k rpms........ but anyways the other day i was drivin it and popd out of 2rd and the car no longer moves.. lol wat is it? trans or clutch? thanks
Old Jun 26, 2007 | 02:38 PM
Bejita's Avatar
Throw out bearing?? Do you have enough fluid in the clutch master cylinder?
Old Jun 26, 2007 | 02:41 PM
Default Re: (Bejita)
yea fluid levels are all good............... also i can throw the trans in gear without pressing the clutch petal down..... and no grinding noise or nuttin
Old Jun 26, 2007 | 03:33 PM
Default Re: (Mr.91lsvtecsi)
Old Jun 26, 2007 | 05:03 PM
Targa250R's Avatar
be professional
Default Re: Need Help On Del Sol (Mr.91lsvtecsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.91lsvtecsi &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a 93 del sol and im havin problems wit trans/clutch area lol the only way to throw car in "R" is to turn the car off.............to throw it in any gear it has to be around 2k-3k rpms........ but anyways the other day i was drivin it and popd out of 2rd and the car no longer moves.. lol wat is it? trans or clutch? thanks</TD></TR></TABLE>
Drop the trans and look at the clutch. If it's broken, replace the clutch. If it's not broken, replace the trans.
You're going to have to drop it no matter what; might as well get started.
Old Jul 1, 2007 | 03:55 PM
Default Re: Need Help On Del Sol (Targa250R)
just changed trans and still the same thing this trans shift alot smoother but i can throw the trans in gear without using the clutch petal!!!! help?
Old Jul 1, 2007 | 04:10 PM
help
Old Jul 1, 2007 | 04:17 PM
jonathan13's Avatar
and the car still doesn't move?? you can run it through all the gears and nothing happens? with it started? i had that problem and replaced the slave cylinder and everything was A ok. might not be the fix to your problem though
Old Jul 1, 2007 | 04:25 PM
Default Re: Need Help On Del Sol (jonathan13)
yea thru all gears and nuttin hold down the clutch you can hear a noise
Old Jul 1, 2007 | 04:26 PM
jonathan13's Avatar
hmmm.. im stumped. good luck man
Old Jul 1, 2007 | 04:27 PM
me 2 man thanks
wat was the issue wit ur car?
Old Jul 1, 2007 | 04:33 PM
Default Re: Need Help On Del Sol (hatch96y7)
axles are in yea car is on jackstand but no type of movement also i can switch gears without touchin clutch petal and no grinds this trans is a lot better than the old one help lol
Old Jul 1, 2007 | 04:41 PM
jonathan13's Avatar
i thought my problem was clutch but we took it out and it was fine so we put it back in and replaced the slave cylinder and it started working lol. might have just been a miracle
Old Jul 1, 2007 | 04:46 PM
lol lol was ur slave moving? clutch was good before the original trans started to crap out.........dunno man **** lol
Old Jul 1, 2007 | 04:58 PM
help need car on the road before the 4th
Old Jul 1, 2007 | 05:17 PM
oh yea both axles are in lol............
Old Jul 1, 2007 | 05:33 PM
helppppppppppppppppppp
Old Jul 1, 2007 | 06:07 PM
anyone?????????????????
Old Jul 1, 2007 | 06:24 PM
JDM-SOL's Avatar
have someone sit in the car while you look at the slave cylinder. Pull the boot back to see if it is plunging into the tranny.
Oh yeah, you can always shift through the gears when the car is off, even if the clutch is not engaged.
I can only give you so much help with the little info you have given. Just make sure you don't have any leaks from the clutch cylinder, resovoir and slave cylinder.
drlagares
18
May 30, 2015 03:46 PM
hatchet37
37
Dec 17, 2014 04:52 PM
JackAcc
Transmission & Drivetrain
Mar 17, 2012 05:02 PM
shady3260
Dec 19, 2009 10:27 PM
PatrickGSR94
17
Aug 3, 2006 08:36 PM
