honda del sol 93 wont move when in gear
i have a 93 honda del sol. i was driving it and when i went to down shift i would rev up but not move. so im thinking clutch or transmission problem or fluid is low but i checked the fluid and it is at safe levels. what i dont understand is that while is idling i cant can stick it in gar with out the clutch and it wont die. So pplease help me i need this fixed asap cuz its my daily driver.
Loves Tossing Salad
Re: honda del sol 93 wont move when in gear
I think what Ron's saying is that the clutch operation could be completely fine, it's the joint not making correct contact with the trans that is causing the symptoms you are experiencing. Could be the clutch but since you said you don't even have to engage the clutch for the car to not die, it could be the trans is spinning freely and the joint is not making proper connection. So it could be a combo of the two and both should be checked
Remove the axle to inspect. Before you do, post pictures of the gap between the CV axle and differential.
