How do you prevent your turbo pipes from blowing off?
Old Jun 6, 2002 | 10:04 AM
BlowOff's Avatar
New User
Default How do you prevent your turbo pipes from blowing off?
This has now happened to me two times. The pipe connected to the intake side of the turbo (on the way to the intercooler) has blown off. How can I prevent this from happening again??
I'm guessing I could get the lip rolled out?? FYI: I'm running custom turbo pipes.
Old Jun 6, 2002 | 10:07 AM
b18bturbo's Avatar
Default Re: How do you prevent your turbo pipes from blowing off? (BlowOff)
you can weld a lip on the pipe and use tbolt clamps. I also reccommend if you are really series weld a bracket to the two pipes thats what we do to keep the race car pipes together.
Old Jun 6, 2002 | 10:12 AM
dbman96's Avatar
New User
Default Re: How do you prevent your turbo pipes from blowing off? (b18bturbo)
I've had great success just welding on like three raised "dots" around the end of the pipes, this keeps the hose clamp from sliding off. I've even done it with dots of JB-Weld or 5-minute epoxy and it holds fine IF the surface is roughed up and very clean before you apply it. That's probably your fastest fix for your problem.
Old Jun 6, 2002 | 10:21 AM
01ITR#700's Avatar
Default Re: How do you prevent your turbo pipes from blowing off? (dbman96)
I either have a bead weld put all the way around at a Local muffler shop or I can drive to Golden and TEC has the machine that puts the little lip on there.
M
Also if it's really bad or your running high boost, then T-Clamps are your friends...
Old Jun 6, 2002 | 10:29 AM
BlowOff's Avatar
New User
Default Re: How do you prevent your turbo pipes from blowing off? (01ITR#700)
Sorry, what's a T-clamp?
I'm running 9lbs now...soon to bee 12-15lbs
Old Jun 6, 2002 | 10:30 AM
b18bturbo's Avatar
t bolt clamps are clap with a bolt and nut very strong...
Old Jun 6, 2002 | 10:32 AM
TurboT's Avatar
yeah, they start at $5 a piece
yikes!
Old Jun 6, 2002 | 10:50 AM
Turbo Laser's Avatar
Default Re: How do you prevent your turbo pipes from blowing off? (TurboT)
krazyglue
Old Jun 6, 2002 | 11:47 AM
bigTom's Avatar
Default Re: How do you prevent your turbo pipes from blowing off? (NOCARLOSER)
brackets
u can see it right by the fuel line... connecting the pipe to one of the tb bolts
Old Jun 6, 2002 | 11:55 AM
TurboSedan's Avatar
New User
Default Re: How do you prevent your turbo pipes from blowing off? (ek9t)
brackets
<IMG SRC="http://www.imagestation.com/picture/sraid22/p9ad4f7df04446a4200d
656424630057e/fdabb886.jpg" BORDER="0">
That is one of the phattest engine bays I have ever seen!!
Old Jun 6, 2002 | 12:22 PM
apexii's Avatar
yikes!
Worth every penny!
Old Jun 6, 2002 | 01:16 PM
TurboT's Avatar
Default Re: How do you prevent your turbo pipes from blowing off? (apexii)
i have a couple if anyone is looking for soem
Old Jun 6, 2002 | 01:18 PM
SIK IN DA HED's Avatar
New User
T-clamps work really well. if you wanna do it the cheap way... just double the claps you already got on now. it works.
Old Jun 6, 2002 | 01:21 PM
dustin's Avatar
Default Re: How do you prevent your turbo pipes from blowing off? (dlplayboy)
what did you expect, look at your username
Old Jun 6, 2002 | 01:37 PM
From Chaos's Avatar
I make small beads with quicksteel. Works perfect, and its not like you have to look at it.
Old Jun 6, 2002 | 01:47 PM
simike's Avatar
Default Re: How do you prevent your turbo pipes from blowing off? (From Chaos)
Check out the McMaster-Carr catalog if you have access to one. I ordered my clamps from there. They were about $3.75ea. These were the ones that open to like 2.625" to work with 2.25" intercooler piping. If you buy more than 10 the price drops even more.
Old Jun 6, 2002 | 01:50 PM
degradated's Avatar
New User
Those clamps solved all my problems with pipes coming apart...
You can get them for $3.99 or so a piece from Napa..
Sticky2K
Aug 28, 2009 08:01 AM
killacam661
Nov 24, 2008 10:46 PM
90teg
Apr 13, 2007 08:57 AM
im sabah
Welding / Fabrication
17
Aug 16, 2004 10:56 PM
X2BOARD
May 31, 2002 07:53 AM
