PLX install
Im reading all the posts on this however im not 100% sure how to install it. Obviously you need power and ground. However I am undersure of how to hook up my white and gray wires since i want to keep my narrowband o2 and weld in another o2 bung. I have been told i need to run a switch on the gray wire to switch the car into narrowband or turn narrowband off or something. Alittle confused to say the least. I am using hondata s300j
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin »</TD></TR><TR><TD CLASS="quote">you wanna run a narrow AND wideband?? why?</TD></TR></TABLE>
Closed loop works pretty well?
Look on Plx's website for wiring info, it will tell you exactly what to do. It's less wiring if you choose to weld in another bung
like you stated you are going to do.
Click on the link in the 3rd question
http://www.plxdevices.com/products/m300/faq.html
like you stated you are going to do.Click on the link in the 3rd question
well i attempted the install and im not sure how to install it because i want to be able to run both open and closed loop and run both o2 sensors. And preferablly run no switch. Everyplace i look it seems like someone does it differently..kinda confusing ...
jdmjunkie86
Feb 14, 2008 02:57 PM
dornon13
Jun 8, 2005 04:05 PM
