PLX Install
Old Nov 9, 2005 | 03:44 AM
XX Boosted Si XX's Avatar
Default PLX Install
Just curious I might be ordering a plx unit for my civic and if i want to use it as a standalone just to monitor a/f ratios, do I need to weld in another o2 bung or still replace my stock primary o2 with the new one? I currently run hondata but I dont tune my car so i dont need to datalog only my tuner does that but i also need to switch back to obd2 for when i go to emissions. Which will be easier method?
Old Nov 9, 2005 | 03:50 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: PLX Install (XX Boosted Si XX)
if your hondata is setup to run in open loop, you can ues it in place if your o2 sensor. or, you can use the narrow band output on the plx and wire that to the o2 input on your ecu and use it that way, but if you dont want to do anything like that, you will need to put another bung in.
Old Nov 9, 2005 | 06:45 AM
adseguy's Avatar
Default Re: PLX Install (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">if your hondata is setup to run in open loop, you can ues it in place if your o2 sensor. or, you can use the narrow band output on the plx and wire that to the o2 input on your ecu and use it that way, but if you dont want to do anything like that, you will need to put another bung in.</TD></TR></TABLE>
exactly...those are your options
Old Nov 9, 2005 | 06:54 AM
Mr. Badwrench
Default Re: PLX Install (adseguy)
i did forget, if you are in open loop and decide to use the plx in place if the factory o2, you will need to complete the circuit for the o2 heater, you can either leave the o2 plugged in, or solder a resistor inline, i dont know the value of the resistor you need though.
Old Nov 9, 2005 | 06:59 AM
HiProfile's Avatar
I just put my plx in, I'm glad I did. Found out my stock exhaust is really restrictive, giving me 10.5:1 AF's while WOT. It wouldn't be that bad - except its not boosted yet! I'm using uberdata for 450's (780's in a few days), just clicked the 'o2 heater disable'.
I think I've seen the resistor value before, you'll have to dig though. Best bet is to let the stock o2 drag on the ground.
Old Nov 9, 2005 | 09:11 AM
turboH22Aakkord's Avatar
on a side note.. and im not sure if this is 100% but the PLX 02 sensor was a different size bung then the bosch one i had on my car.. so i ended up using 2 bungs anyhow...
Old Nov 9, 2005 | 09:30 AM
nota-eg's Avatar
Default Re: PLX Install (turboH22Aakkord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord &raquo;</TD></TR><TR><TD CLASS="quote">on a side note.. and im not sure if this is 100% but the PLX 02 sensor was a different size bung then the bosch one i had on my car.. so i ended up using 2 bungs anyhow...</TD></TR></TABLE>
Was the bosch different than the stock one? I have the PLX M-300 and it fits right into the stock bung on the manifold, as well as the bung on my DSM turbo.
Old Nov 9, 2005 | 10:34 AM
Default Re: PLX Install (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">
Was the bosch different than the stock one? I have the PLX M-300 and it fits right into the stock bung on the manifold, as well as the bung on my DSM turbo.</TD></TR></TABLE>
well ill be damned.. mine were two different sizes.. i think teh one for the plx is an 18mm or someting.. i dontremember but the bosch one was def. bigger... just my luck i guess haha
Old Nov 11, 2005 | 08:35 AM
streetrays's Avatar
to add, if you want to use the narrowband output of the unit (feeding into ECU), then the resistors to be soldered inline are usually included.
Old Nov 15, 2005 | 12:56 PM
Default Re: (streetrays)
just curious where did you guys run your power and ground if your just using it as a stand alone?
Old Nov 16, 2005 | 07:47 AM
streetrays's Avatar
Any accesory 12v and chassis ground point..
Old Nov 16, 2005 | 07:53 AM
yellowturbo's Avatar
did you guys used the kinda resistor that came with it... I fucked mine while trying to solder them and I lost the second one ( those pieces are so tiny and fragile ) anyway the PLX WB seems to work great without them too.
The only thing I noticed is that the reading display really fast... is there any way to adjust that in the AME EMS ?
Old Nov 16, 2005 | 07:56 AM
streetrays's Avatar
well, those resistors are used when you're feeding the output of the WB unit to ECUs..
there isn't any way to adjust the update rate of the display unit.. but if you're logging/analyzing the output of the WB unit, you can always turn the sampling rate down right?
Old Nov 21, 2005 | 02:50 PM
streetrays's Avatar
so, what do you think, XX Boosted Si XX?
after running the unit?
don't worry about the word "LEAN" PLX is just being nice to help you interpret the numbers and display something useful.
Old Nov 21, 2005 | 02:51 PM
works great, easy install, my air/fuel ratios are very close to what i was tuned for...thanks again
Old Nov 21, 2005 | 05:08 PM
mike93eh
Guest
Posts: n/a
https://honda-tech.com/zerothread?id=1422548
Old Nov 21, 2005 | 06:41 PM
streetrays's Avatar
thank you, mike93eh..
that's the info he needs..
Old Nov 21, 2005 | 06:47 PM
mike93eh
Guest
Posts: n/a
no problem
btw, i ended up just welding a new bung in, since the other one was too close to the turbo.. it was really easy. from start to finish, it took me about 2 hours to install the plx..
Old Nov 21, 2005 | 07:48 PM
streetrays's Avatar
perfect
Jeffro1265
Aug 17, 2010 12:05 PM
BDogggUT34
Aug 2, 2007 03:22 PM
dornon13
Jun 8, 2005 04:05 PM
JDMlyfestyle
Mar 30, 2004 09:48 AM
Prelude91siT
Nov 16, 2003 10:54 AM
