What would I need to install these?
This id a picture of what I have. What do you think I will need to do to install them? I know I am missing wiring but how do you go about wiring them up?
* B A N N E D *
Re: What would I need to install these? (jdmjunkie86)
You will need some type of wire to go inside the either to the fuse or to a switch. Try to find a one that goes to the fuse from another ek so that you can hook up your fogs to the fog switch in the car (which you will aslo need to locate should come off same car) this would make things cleaner, but you could just hook it up to a custom switch from like Autozone or somethin. If you do that you must have wire that taps into a power source in your ignition wires then goes to the switch.
Re: (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars »</TD></TR><TR><TD CLASS="quote">is this a rally car?</TD></TR></TABLE> No its not, those are optional fog lights for the 96-98 civics. Your going to need wiring which is easy, just look online for a universal fog light wiring diagram.
Re: (2redstars)
close.... 96-98 civic oem foglights. Looks like your just missing the on off switch and the wiring harness
Re: (jdmjunkie86)
The OEM Foglight Kit includes Harnesses for the Interior (under the Steering Column) and Engine Bay. It looks like those are missing. I'm pretty sure Eran in the Lighting Forum can guide you along whatever path you need to take from here.
Best of luck!
JasonGhostz
Best of luck!
JasonGhostz
michael_antoi
10-16-2006 03:08 PM
RuthlessEF-9
02-15-2005 02:42 PM
MickREXor
10-16-2004 08:54 PM
