Problem with clear yellowing
Old Jun 23, 2007 | 10:44 AM
nihkon's Avatar
Default Problem with clear yellowing
I'm touching up my engine bay a little bit. I sprayed (with a can) some white touch up paint. Then I went over it with some high temp. clear. It looked great for a few days, then it began to yellow a bit.
Is this due to the type of clear I used? Or maybe I laid the coats on a little too thick? Or what?
Are there any spray can clears that are better quality that won't yellow?
Here's the paint I used:
And here's the section of my engine bay that I painted:
You can see that the engine bay no longer matches the outside of the fender. It did match pretty well before it yellowed.
Old Jun 23, 2007 | 09:12 PM
LShatchie's Avatar
Default Re: Problem with clear yellowing (nihkon)
same thing happened to me...
Old Jun 24, 2007 | 02:00 PM
dude_123's Avatar
Those can clear are cheap, try some rubbing alcohol on it and you will see what I mean.
Old Jun 28, 2007 | 02:22 PM
nihkon's Avatar
Default Re: Problem with clear yellowing (dude_123)
Any help guys?
Old Jun 28, 2007 | 02:29 PM
BoogieDownBrown's Avatar
Most cheap clears have a yellow tint to it. The more expensive brands like House of Kolors is crystal clear, but its not cheap like i stated.
Old Jun 28, 2007 | 02:55 PM
nihkon's Avatar
Default Re: Problem with clear yellowing (BoogieDownBrown)
Can you get House of Kolors clear in a spray can?
Old Jun 28, 2007 | 03:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihkon &raquo;</TD></TR><TR><TD CLASS="quote">Can you get House of Kolors clear in a spray can?</TD></TR></TABLE>
NOPE!!!!!!!!!!
Old Jun 28, 2007 | 03:20 PM
nihkon's Avatar
Lol.
So what is it that causes the yellowing? It definitely didn't look like that when I first sprayed it. It took a few days to develop into the yellow tint it has now.
Old Jun 28, 2007 | 03:37 PM
NotoriousEK's Avatar
I think its just that clear that yellows. The reg. clear that they sell will work
I have noticed the engine enamel clear turns yellow when its dry, I tried it on my headlights once
Old Jun 28, 2007 | 03:45 PM
nihkon's Avatar
Default Re: Problem with clear yellowing (NotoriousEK)
Doh! Well I guess it looks like it's time for me to invest in a paint gun!
Old Jun 28, 2007 | 03:57 PM
powerflow's Avatar
There you go A descent 2K clear would work way better.
Old Jun 28, 2007 | 05:07 PM
nihkon's Avatar
Default Re: Problem with clear yellowing (powerflow)
Thanks!
I'd be lazy and ask you for info and a link to the 2k clear that you mentioned. . .but I should probably do some research on paints/guns anyway if I'm going to get into "real" painting. haha
Old Jun 28, 2007 | 07:38 PM
powerflow's Avatar
2k = 2 component, any paint material that combines 2 different parts to make 1 catalyzed / activated part is 2k. Primer, base, clear can all be considered 2k if mixed w/ an activator or hardener.
Old Jun 29, 2007 | 02:13 PM
Ep1dem1c's Avatar
you can go to a local shop that makes auto paint and they can put anything in a can. If you buy HOK clear you can take it them and they can put it in a can for a small fee. Also I'm still trying to figure out why you are using high temp paint on an engine bay? that is for engine blocks and heads not engine bays..
Old Jun 29, 2007 | 02:14 PM
Ep1dem1c's Avatar
Default Re: Problem with clear yellowing (Ep1dem1c)
BTW the heat that your motor puts off cures that paint so just use some krylon clear and see what happens.
Old Jun 29, 2007 | 04:04 PM
ivannaciv's Avatar
Isnt oxidation a part of the yellowing? I was just wondering.
Old Jun 29, 2007 | 05:24 PM
Bigblockhatch's Avatar
Default Re: (ivannaciv)
It may be turning yellow because its heavy in those areas..Some clears have a yellowish tint(its a UV protectant)in them to help with weather.But u cant see it when sprayed
Old Jun 29, 2007 | 09:36 PM
nihkon's Avatar
powerflow: thanks for the info buddy!
Ep1dem1c: Oh yeah, I've heard about getting spray cans filled. I forgot all about that. Maybe I'll look into that to see how much it costs. I used the engine paint with the thought that it would hold up to the heat of the engine bay a little better than regular clear. [shrugs]
Bigblockhatch: Yeah that may be. I did spray a bunch of coats, so it's probably pretty thick. And it is most yellow in the area in front of the wiper motor hole where I got a little trigger happy and it pooled up slightly.
Old Jun 30, 2007 | 07:52 AM
Ep1dem1c's Avatar
good luck... it doesnt look as bad as you think it does it actually looks pretty good for an at home job
oh and where did you get your bolts/washers from the green ones? ive been looking for those for a while now and cant find em... i heard pep boys? let me know because i want to get some red ones thanks
Old Jun 30, 2007 | 09:09 AM
nihkon's Avatar
Thanks man! Yeah in the right light you can't even see the yellowing. But it's enough to bug me. lol!
As for the washers. . .I got them from a local "ma and pa" type fastener shop here in SoCal. I searched around online for a while as well and couldn't find them either.
Old Jun 30, 2007 | 10:12 AM
Ep1dem1c's Avatar
are their specific sizes for the bolts? or a brand name?
Old Jun 30, 2007 | 10:44 AM
nihkon's Avatar
I don't think there was a brand name on the washers. They just call them "beauty rings."
As for the bolts, again, no brand name. I used chrome button head allen bolts. They are 6mm. I cant' recall exactly the length I got. I think they were 20? 21? Something like that. I like the button head bolts because they're a little more flush than the regular allen head bolts. And they aren't played out as much as the torx bolts. lol
Just to warn ya though, that stuff isn't cheap. Between the bolts, a/n washers, and beauty rings (yeah, each bolt is a 3-piece setup). . .that stuff cost around $70.
Old Jun 30, 2007 | 10:54 AM
Ep1dem1c's Avatar
price...
looks are worth it though
thanks alot im going to search around and see if i can find something...thanks
Old Jul 2, 2007 | 09:16 AM
Officer's Avatar
WALMART has some house of colors-Spray Can Clears. They are super small cans for like 5 bucks each.
Because im going to use it for my pocket bike.
JGTW
Paint and Body
Oct 18, 2018 06:09 AM
JDM_SOHC
Paint and Body
Nov 1, 2008 04:05 PM
Jvs10
Paint and Body
Aug 31, 2008 06:23 PM
crxzcracer
Paint and Body
12
May 7, 2008 05:39 PM
DAGSR17
Paint and Body
May 17, 2007 04:57 AM
