can you weld different metals together?
i am a noob but want to take my oil pan to the weld shop(d16y7 pan) i dont know if the pan is steel or alum, and my turbo oil out let fitting(the fitting i want to get welded to the pan) it is brass. sorry for the noob questions i did search.
Yup. Steels to steels, yes, but pretty much anything else to steel, or anything Ti/Mg/Al/Brass nope. There has been some research on hi-energy fusion welding of Ti to Al, but its the sort of thing NASA has been researching. There's no hope of anything like that happening on a reasonable budget.
Basically, you are SOL if you want the fitting welded on. You could get them to weld on an NPT internal threaded bung, then thread your drain fitting into it, or get a steel/Al fitting welded on, and use that.
I know you can use explosive welding to weld disimilar metals. They use it to make a metal called clad its used in alot of nuculear powerplants
I saw this guy bring this stuff over and weld mild steel to aluminum and it was basically brazing rds but its cheap.
http://www.muggyweld.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat »</TD></TR><TR><TD CLASS="quote">well i could prob find a nut that will fit into my fitting and then just weld the nut to the oil pan right??.(not me personally weld it but get somebody to.)</TD></TR></TABLE>
ya, most likely the brass fitting has pipe threads on one end. Go to the hardware store with the fitting and buy a female thread fitting. you can cut it down and weld it right to a stel pan. Then the fitting would be removable or if you ever wanted to go with an AN fitting you could just replace the brass barb with it.
TrueUntilDeath.com
Welding / Fabrication
Feb 2, 2005 07:06 AM
filetofit
Nov 1, 2002 03:26 PM
