Clutch issues
Old Jun 22, 2007 | 07:28 PM
fast91stealth's Avatar
Default Clutch issues
I have a 97 with a b16 hydro tranny. Last week the master cylinder decided to go. I replaced that and also replaced the rubber line with a stainless steel one. Now I have bleed the heck out of the system but no matter what it will not build pressure. There are no leaks and all connections are tight. What else is there to check?
Old Jun 22, 2007 | 07:29 PM
Mr.EM1_EK's Avatar
Default Re: Clutch issues (fast91stealth)
maybe your slave cylinder.
Old Jun 22, 2007 | 07:30 PM
Default Re: Clutch issues (Mr.EM1_EK)
Thats what I am wondering but could it be bad even if it doesn't leak and bleeds fine. Also how far out should the slave be and how much play should the fork have in it? The slave seems to be extended out a lot and the fork is sloppy with the slave off. There is no leak from the slave though.
Modified by fast91stealth at 8:45 PM 6/22/2007
Old Jun 22, 2007 | 07:34 PM
Mr.EM1_EK's Avatar
yeah, anything is possible. i have bled master cyl. fine but would still not get good pressure at the pedal. they have seals in them that can go bad.
Old Jun 22, 2007 | 07:35 PM
ilovemycoupe's Avatar
I'm a Jackass
mine went bad with NO SIGNS OF WEAR AT ALL....
so yes it's possible i'd change it, its not that expensive and fairly easy to install
iheartmy94eg
Jul 11, 2008 03:18 PM
ATS*Mark
Aug 23, 2005 09:55 AM
matto2413
Jul 16, 2005 07:08 PM
integls95
Jan 1, 2003 09:25 PM
743power
May 22, 2002 04:18 PM
