heat wrap
Old Jun 21, 2007 | 08:20 AM
thechamp2633's Avatar
* B A N N E D *
Default heat wrap
heat wrap......does it work?
Old Jun 21, 2007 | 08:22 AM
jdmdc10's Avatar
yes.
Old Jun 21, 2007 | 01:19 PM
GSRpoweredSI's Avatar
Default Re: (jdmdc10)
whats the purpose for heatwrap. i see it done but is it that hard and that worth it?
Old Jun 21, 2007 | 01:26 PM
97Ej6mike's Avatar
Default Re: (GSRpoweredSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRpoweredSI &raquo;</TD></TR><TR><TD CLASS="quote">whats the purpose for heatwrap. i see it done but is it that hard and that worth it?</TD></TR></TABLE>
Contains and lessens the heat emitted from turbo, manifold, header and sometimes downpipe. It can be done on an N/A car's header, but its best used on turbo applications, they make a large amount of heat discharge in and around the motor bay, helps keep a large amount of heat within the exhaust pipes.
Mongo say lots of heat bad for motor.
Old Jun 21, 2007 | 01:33 PM
Eran's Avatar
HT White Ops
Heat wrap has two main benefits:
1) The hotter your exhaust, the thinner (read. less dense) it is, and the easier it flows. This allows your exhaust gasses to move out of your manifold faster.
2) Decreases heat soak to things around the manifold.
It also has some major downfalls, though.
1) It can trap moisture and lead to expansion/contracting in hot and cold (can crack it), and can cause rust.
2) It does dramatically increase the temperatures inside your manifold, and can compromise the integrity (can crack it).
Old Jun 21, 2007 | 03:36 PM
MJ0LNIR's Avatar
Default Re: (Eran)
Also, I've done some research on heat wrap for motorcycles in the past. A major problem is that it does what it does- namely, it traps heat in. This prevents the metal from dissipating heat properly and can weaken the metal and make it brittle.
8YourV8
17
Dec 31, 2010 04:14 PM
fraserboostedh22
Jun 26, 2009 08:03 PM
PearlH22
Jun 24, 2006 06:05 PM
SpoonFedHatch
Apr 22, 2004 11:25 PM
01ITR#700
Jan 11, 2003 04:38 AM
