ECU Help
Old Jun 21, 2007 | 07:18 AM
EF Driver's Avatar
Default ECU Help
Is it possible to use a OBD2 ECU on a crx?
Old Jun 21, 2007 | 08:23 AM
mahatma's Avatar
Default Re: ECU Help (EF Driver)
no
fuggedaboutit
Old Jun 21, 2007 | 09:13 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF Driver &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to use a OBD2 ECU on a crx?</TD></TR></TABLE>
Not unless your CRX is converted to OBD2, no.
Old Jun 21, 2007 | 12:28 PM
EF Driver's Avatar
Default Re: ECU Help (wiZCo)
how do u convert the car to obd2?
Old Jun 21, 2007 | 12:32 PM
abnaasefmb's Avatar
welcome to h-t. please take some time to read the FAQ in the sticky.
yes you can, but you would not want to run obd2.
Old Jun 21, 2007 | 01:23 PM
EF Driver's Avatar
Default Re: ECU Help (abnaasefmb)
i just wanna know because im getting the whole ecu harness and ecu and engine harness with the D16y8 motor and instead of buying a new ecu and jumper harnesses is there a way i can use the obd2 ecu for temporary until i get enough money for the obd2 to obd1 harness and the ecu
Old Jun 21, 2007 | 07:44 PM
EF Driver's Avatar
bumpp
Old Jun 21, 2007 | 07:52 PM
yz125rider21's Avatar
no....a whole lot of rewiring which you probably cant do sense you havent noticed the search button...but you ahve a crx so your gonna want a obd0-obd2 if you want that route but the route anyone well tell you to go with is obd0-obd1....or just stay obd0 and get rig up a msd vtec switch for that head...
Scott Little
Feb 3, 2020 06:18 PM
mojackson2390
13
Aug 20, 2008 03:16 PM
killacam661
21
Aug 7, 2007 07:45 AM
4drb18ek
Mar 1, 2003 07:42 AM
