2nd gen B16a problem.
hey gurus, I have a problem with my 90 si hatch with a second gen B16a engine. first off, its currently running on a pr4 ecu, which is a non-vtec ecu from an ls integra. the previous owner wired it with a device that engages vtec at 3k rpm. My question is what will I need to do in order to do a proper wiring job on my car. I know the engine is obd1. what obd is my car? what wire harness will I need to get inorder to wire my engine up properly, and what ecu should I use? thanks.
Also, I have a problem with my breaks. I've already bleed them starting RR, RL, FR, FL but when I'm driving and step on the breaks, it goes to the floor. could it be the break booster? thanks in advance.
you have 2 options
Obd1 P30 or PR3
http://www.rywire.com to covert your harness or do it yourself. There are write-ups somewhere
use obd1 injectors, obd1 dizzy, 4 wire o2
or
Obd0
Pr3(obd0) or PWO
http://www.rywire.com get their vtec sub harness
use (2) 1 wire o2 sensor, obd0 Dizzy, obd0 injectors with resistor box
The injectors interchange you can use obd1 injectors without the resistor box in obd0 car, or run your obd0 injectors on a obd1 if you use the resistor box.
As far as your brakes go. it is probably you Master Cylinder (95% of the time). usually when the brake booster goes bad... your pedal is really stiff.
Obd1 P30 or PR3
or
Obd0
Pr3(obd0) or PWO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by howangseg »</TD></TR><TR><TD CLASS="quote">thanks for the advice guys, but which options would be best. i just want a reliable dd. thanks again.</TD></TR></TABLE>
Honestly obd1. Costs more lil more work, well worth it though.
http://www.boomslang.us
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HonDelso »</TD></TR><TR><TD CLASS="quote">you have 2 options
Obd1 P30 or PR3
.</TD></TR></TABLE>
best option above
or you can use a chipped p28 with a p30 stock base map
Obd1 P30 or PR3
.</TD></TR></TABLE>
best option above
when i did my B16a2 into my 91 crx i used the si harness wired OBD1 injectors and dizzy into the harness bypassed the resistor box bought OBD0 to OBD1 jumper harnes and just wire the o2 senor, v-tec, and a knock sensor and run it on a p28 and it should run like a champ...thats how 2 of mine were done i have no c.e.l. and i run a chipped ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by domepeezo1 »</TD></TR><TR><TD CLASS="quote">when i did my B16a2 into my 91 crx i used the si harness wired OBD1 injectors and dizzy into the harness bypassed the resistor box bought OBD0 to OBD1 jumper harnes and just wire the o2 senor, v-tec, and a knock sensor and run it on a p28 and it should run like a champ...thats how 2 of mine were done i have no c.e.l. and i run a chipped ecu</TD></TR></TABLE>
vtec
vtec
JDM B16A
11
Jun 20, 2006 09:50 AM
