ecu problems
Old May 8, 2010 | 06:27 PM
BROCKMYSTER's Avatar
Icon6 ecu problems
hey wats up guys i need some help
i have a da with b16a and im still in the swap process
i used my da engine hardness with the b16 it starts and everything
but i know the ecu needed to be replaced so i got a pw0 ecu but now it wont turn on
i have a vtec sub-hardness connected and everything is ok
i don't get y it doesn't turn on it cranks but doesn't run
the light in the ecu stays on is that a problem ?
do i need to get it chip ?
future thanks guys
Old May 10, 2010 | 12:48 AM
SpeedjunkieDB1's Avatar
Default Re: ecu problems
First of all is the engine OBD0 or OBD1? cuz the P0W ecu is OBD0 so if your engine is OBD1 you need a OBD1 ecu like a P06 or a P28 and you need a OBD0 to OBD1 jumper harness and you can use your stock harness but you have to cut and add some clips cuz they're not the same that is if your engine came with a harness too, cuz the dizzy is different and the ecu wont read it, you need a OBD1 dizzy as well that's why it's not starting cuz the sensors inside the dizzy are different so check into that.
Old May 10, 2010 | 05:45 PM
my engine and ecu are both obd0
i got the ecu fixed it had a chip but with nothing on it
now the cars starts but wont rev past 4000 rpm
any suggestions on wat it might be my check engine is on plus cant take it no where cause its on jack stands
Old May 10, 2010 | 09:00 PM
jdm_bones's Avatar
I have a OBD0 PR3 ecu virgin, I am in South Gate, send me a PM if you want to pick it up for $80. Sounds like there is something wrong with your current ECU, who chipped it for you?
Old May 10, 2010 | 10:35 PM
Who ever chip your ecu set a two step launch control thats only when you're sitting at a stop light ready to race. Well do you revv it in neutral? cuz that's normal but it's not normal when driving and in gear check for that. And also check your timing.
Old May 11, 2010 | 06:08 PM
all fixed it was a bad ecu everything running good now
thanks to jdm_bones for looking out
Old May 11, 2010 | 08:20 PM
jdm_bones's Avatar
No problem, if you ever need help hit me up, if you ever decide to build something hit me up!
Old May 11, 2010 | 08:55 PM
will do
HuntsAlone
60
Jun 18, 2015 04:26 PM
DA9Sleeper
Apr 15, 2011 02:38 AM
golf-mk3
Sep 18, 2010 09:43 AM
DohctorVtec
Jun 3, 2005 01:15 PM
G2integra217
May 8, 2005 11:39 PM
