fixed car, new problem B16
Old Jun 15, 2007 | 03:55 PM
EL_DURO's Avatar
Default fixed car, new problem B16
so I fixed the problem how it was hesitating to go and stuff, i just changed the distributor wires, spark plugs, and o rings. i have anew problem, where my redline is wicked low, like around 5 grand. i think its fuel starvation, idk tho. wat do you guys think?
jdm 2nd gen b16
thanks a lot
Old Jun 15, 2007 | 04:13 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: fixed car, new problem B16 (EL_DURO)
possible tps, got a scan tool, or access to one?
Old Jun 15, 2007 | 05:44 PM
Rdriver's Avatar
Default Re: fixed car, new problem B16 (95DxSi-R2)
Are you still getting a check engine code?
Old Jun 15, 2007 | 08:03 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: fixed car, new problem B16 (Rdriver)
What ecu are you using?
CEL?
Old Jun 15, 2007 | 08:20 PM
EL_DURO's Avatar
Default Re: fixed car, new problem B16 (ek forever guy)
um i havent gotten a check engine code in a while. usualy when i engine brake a lot but i havent done that so i will try tomrow to c if it goes on. i have the stock ecu idk wat its called. il ask my bro n let u kno. thanks a lot for your time guys
Old Jun 15, 2007 | 08:24 PM
Ek Forever y0!
The stock ecu for what?
if it's the ecu you had before the swap, it's not going to work right.
Is it an b16 ecu? Or a sohc ecu?
Old Jun 16, 2007 | 12:33 PM
EL_DURO's Avatar
its the ecu that came with the swap. and i checked today and engine light still goes on when i engine break. i dont hear vtec either but my bro says he hears it, idk wat hes talking about tho lol. i will check my tps. thanks guys
danteisme
Nov 2, 2007 02:25 PM
90crxdxb16
12
Nov 27, 2006 03:09 PM
crxsk8er957
Dec 8, 2004 10:53 AM
Fatty_1775
Jul 10, 2003 10:14 AM
fastcat1
Dec 30, 2002 05:26 PM
