ecu problems?
ok, after a reoccuring problem i cant fix on my car i took it to the dealerhsip today. they cant figure it out either, they said the ecu may be goin bad. how does one check that for issues?
If you paid them to tell you that it MAY be the ecu, i would tell them to give me my money back. That's not a diagnosis that's BS. Ask them what happens if you buy a brand new ecu from the dealer and it doesn't solve the problem, will you get your money back for the ecu? What's your reoccuring problem in the first place?
Its probably not the ecu, honda ecus dont go bad that offten there are alot of other things that would go bad before the ECU would like anything inside the distributor, the fuel pump, sensors, ect. There is a way to check, if you have a steady check engine light when you try to pull a code its your ecu.
it throws a cel for the iacv and both 02 sensors, never do these come up seperately, always all at once. when the code comes up, the car stalls, dies, and then wont restart. however, if you wait long enough, and re-start the car, it runs fine, and the codes are gone. it wont even save them in a history which is why they think the computer is bad. when you shutoff the car and restart it, it gets rid of any previous codes by itself.
the iacv and the 02 sensors were replaced 2 weeks ago as well, they checked on those specific parts and said they are functioning as they are supposed to
da9blk1
Jul 19, 2010 08:04 PM
