honda won't start
I need some help!!
I just changed the head gasket on my 95 honda civic 1.5 liter engine. The intake and exhaust manifold are screwed in fine. All the hoses have connected. The distributor has also been re-installed with the same wires, I changed the spark plugs to NGK.
The engine is turning but will not start, the car is also a 5 spd. Why is this happening?
if the ground wire is not bolted down it will not ground the main relay and you will not be able to get the car started. the dist is almost impossiable to get 180 deg off unless you took the dist apart and removed the keyed gear.
l.holmes
May 18, 2016 11:12 AM
