tuning on a hot day?
Old Jun 6, 2007 | 03:32 PM
builthatch's Avatar
MiG-21 superfan
Default tuning on a hot day?
tuning at evans on friday and it's supposed to be in the 90's with low humidity. i'm not entirely happy about that but he's so booked i have to stick with the appointment.
bad idea or what? i care solely about the quality of the tune since i don't drive around most of the time in such heat!
Old Jun 6, 2007 | 06:08 PM
spectacle's Avatar
Default Re: tuning on a hot day? (builthatch)
tune for the worst so you always have the best...in this case since the heat will be extreme for you the car will respond better during lower temps.
Old Jun 6, 2007 | 07:37 PM
NJIN BUILDR's Avatar
Default Re: tuning on a hot day? (spectacle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spectacle &raquo;</TD></TR><TR><TD CLASS="quote">tune for the worst so you always have the best...in this case since the heat will be extreme for you the car will respond better during lower temps. </TD></TR></TABLE>
^^It will also be very lean on a cold day.
To answer the op question is your going to an experienced tuner so you will be fine.They will make the proper allowances for the weather.
Old Jun 9, 2007 | 08:17 PM
blackeg's Avatar
Default Re: tuning on a hot day? (NJIN BUILDR)
damn man good deal on the evans appt. i wanna go but he's book till late august.
ive seen changes of around .5 afr going from 80 degree weather to 40 degree weather. are you using neptune?? if so ive heard nothing but excellent things about the iat corrections and its smooth driveablilty
Lithel
Feb 29, 2008 07:57 AM
end005
Feb 1, 2008 03:25 PM
BigSam
Jul 18, 2007 03:47 AM
K-Spec
Oct 1, 2006 05:35 AM
SiR99
Jun 15, 2006 03:53 PM
