ls motor swap help!!
Old Jun 6, 2007 | 11:51 AM
93sihatchy's Avatar
Default ls motor swap help!!
Ok i got a 93 si hatchy and putting a ls motor into it..
1.what wiring harnes will i need to use the stock 1 or the ls harness?
2. i must use the ls ecu right?
any other problems that i will run into ?
ht
Old Jun 6, 2007 | 11:57 AM
elmo908's Avatar
Hey, I just finished the same swap. I decided to use the LS harness but either one will work. You may want to keep your si harness if you decide to go vtec later on. In order not to get any engine codes I would most definately recommmend using the LS ecu. It is a pretty straight forward swap other than that. I used the integra mounts all around and the torque mounts that were on the b20 before this motor. Good luck on the swap.
Old Jun 6, 2007 | 12:00 PM
93sihatchy's Avatar
Default Re: (elmo908)
ty.. going to go pick up the harness today.
Old Jun 6, 2007 | 12:48 PM
elmo908's Avatar
good stuff bro, good luck. Hit me up, if you need any help because its still pretty fresh in my mind.
Old Jun 6, 2007 | 12:51 PM
dannis.'s Avatar
remember to get the ls throttle cable or your gonna have to fab some braket.
Old Jun 9, 2007 | 05:52 PM
96hatchy's Avatar
Default Re: (dannis.)
im selling my car but wutever car i get im gonna do an LS swap in it. (planning on getting a civic or del sol.) how hard is it. its quick power, cheap, and easy to boost. my main thing is how hard it will be. wut all do i need.
i know i need the motor,intake and exhaust manifold,fuel injectors,fuel rail,tranny, wiring harness, distributor, ECU,mounts. any thing else im missing. let me know. and can i still get ac with this swap. thnx
Old Jun 9, 2007 | 11:57 PM
elmo908's Avatar
Keep you stock airbox and use the intake runner from the LS to run from airbox to throttle body. It's an easy swap. You can still get ac with this swap.
Old Jun 10, 2007 | 06:10 AM
96hatchy's Avatar
wut about keeping p/s
Old Jun 10, 2007 | 06:19 AM
civicslayrx's Avatar
Default Re: (96hatchy)
https://honda-tech.com/zerothread?id=856396
Old Jun 10, 2007 | 07:06 AM
96hatchy's Avatar
Default Re: (civicslayrx)
thats 4 a gsr swap. i need 1 for a LS swap. i heard swapping a vtec motor means extra ****.
Old Jun 10, 2007 | 07:36 AM
erixxxhouse's Avatar
This had been covered. Search.
Old Jun 10, 2007 | 03:40 PM
hey... pshhhhhtttttt. THERE IS A FAQ AT THE TOP OF THIS FORUM, i think it might be able to help you. Quiet though alot of newbs act like its a secret. Heres another secret, Search is your friend https://honda-tech.com/zerosearch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEARCH &raquo;</TD></TR><TR><TD CLASS="quote">Your search for ls swap into eg returned 676 results.</TD></TR></TABLE>
preetyboi06
Jul 17, 2009 09:57 AM
Salad Fingers
12
Jan 22, 2006 01:07 PM
blubandit8
Sep 5, 2002 02:38 PM
jdmekcivic2eg
Mar 20, 2002 06:50 PM
