Transmission help, 2 gear grindage.
Old Jun 5, 2007 | 04:24 PM
Hopesfallx2m's Avatar
Default Transmission help, 2 gear grindage.
have a honda civic 2000 d16y8.
well when im driving and i shift to second it sounds like it strips and sometimes it doesnt go in it just shakes my hand, and other times it just grinds very very hard. i do kno my throwout bearing is shot, and i think my sync rows are going for 1st to 2nd and when i shift to 3rd it grinds a lil but my main concern is second gear, what can i do to fix this problem.
thanks
oh would it be better to buy a new tranny or get this one rebuilt?
Old Jun 5, 2007 | 05:01 PM
EG2Driver's Avatar
Default Re: Transmission help, 2 gear grindage. (Hopesfallx2m)
could be that the trowout bearing is not releasing the pressure plate all the way. My car did that before, shifting was really hard. Turned out my clutch disk had broken.
Syncromesh, not sync rows
Old Jun 5, 2007 | 08:42 PM
thanks i'll get that check out, how much money??
Old Jun 5, 2007 | 09:22 PM
killerB16A's Avatar
Default Re: (Hopesfallx2m)
you can get another tranny for like 250-300 that would be a better rout.
Old Jun 6, 2007 | 08:59 AM
EG2Driver's Avatar
Default Re: (killerB16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">you can get another tranny for like 250-300 that would be a better rout. </TD></TR></TABLE>
especially since its a D-series. To replace the trowout bearing, you'll need to take the tranny off. Might as well replace the clutch/pressure plate along with the rear main seal while you are there...ebay has some Exedy OEM replacement kits with all of that for 120$.
Old Jun 6, 2007 | 12:48 PM
so how long do i have its not really bad but its getting there.
Old Jun 6, 2007 | 12:55 PM
hatchling37's Avatar
Well, put it this way. You can drive around in that time bomb and hope that you don't get stranded somewhere in a no-cellphone-signal zone, or you can buy a new tranny, put in a good clutch and replace all your seals and not have to worry anymore about that hunker.
It could be that your shift fork is bent or something has been knocked out of alignment. That would cause the grinding and cause it not to want to stay in gear.
Old Jun 6, 2007 | 08:48 PM
well would this be that i learned how to drive a manual with this car about 5 months ago, im pretty good now, but when i started i grinded gears all the time. but since i got better is when it strated breaking.
Old Jun 7, 2007 | 10:04 AM
zfreak's Avatar
Have you checked the fluid level in your trans?
Changing out the fluid with Honda MTF will only cost about $12. It fixed my 4th gear grind, although it wasn't as bad as you described yours.
Good luck
Mike M.
94JDMcivic
Aug 23, 2006 04:35 PM
igotboost
Jul 30, 2006 06:23 PM
Pretty Hot And Tuned
Jul 27, 2005 06:57 PM
99turboeg
Jun 5, 2005 01:42 PM
FIxALPHA
Sep 10, 2003 04:47 PM
