Code 7 TPS - Checked Voltage - What else could it be?
Old Jun 5, 2007 | 03:48 PM
b18cEK's Avatar
Default Code 7 TPS - Checked Voltage - What else could it be?
My car throws the tps code every now and again.
I normally just disconnect the battery cable and it goes away.
I checked voltage and it is good with .49 at idle and 4.54 at wot.
So, what could be causing this code to keep being thrown?
Old Jun 5, 2007 | 04:25 PM
pdiggitydogg's Avatar
Voltage between 1 & 3 spec is ~5v (this is at the harness, with the key 'ok' not playing with the throttle)
Resistance between 1 & 2 spec is .5-.9k
Resistance between 2 & 3 spec is ~4.5k
(both closed)
Old Jun 5, 2007 | 05:08 PM
nsxmatt's Avatar
Default Re: Code 7 TPS - Checked Voltage - What else could it be? (b18cEK)
Check the pin in the harness on the pass side shock tower. It can sometimes come loose and cause a random CEL.
Mr.Death
Apr 30, 2010 05:51 PM
ludacole
Aug 13, 2005 11:59 PM
Mach69
Jul 19, 2005 11:47 AM
dingusjt
Nov 7, 2003 07:45 AM
