ALIGNMENT setting for a lowered daily driver....
Old Jun 4, 2007 | 02:10 PM
akunamatta's Avatar
* B A N N E D *
Default ALIGNMENT setting for a lowered daily driver....
i am taking my 92 civic cx into an alignment place tommorow and need some information... the hatch is currently resting on skunk2 pro-s coilovers on all four corners along with S2 fully adj. camber kits F+R. ......
Old Jun 4, 2007 | 02:40 PM
d357r0y's Avatar
Default Re: ALIGNMENT setting for a lowered daily driver.... (akunamatta)
stock settings should be a-ok
Old Jun 4, 2007 | 05:54 PM
EK_B's Avatar
Just get your Toe to be closest to OEM-spec.
Old Jun 5, 2007 | 06:53 AM
akunamatta's Avatar
* B A N N E D *
Default Re: (EK_B)
stock? lol i was planning on having a more severe camber angle and playing zeroing out the toe.....
Old Jun 5, 2007 | 07:18 AM
d357r0y's Avatar
Default Re: (akunamatta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta &raquo;</TD></TR><TR><TD CLASS="quote">stock? lol i was planning on having a more severe camber angle and playing zeroing out the toe..... </TD></TR></TABLE>
That's what the camber kit is for.
Old Jun 5, 2007 | 08:14 AM
JMelt4's Avatar
If you are planning on having some random shop play with your camber kit, man, you better pray they know what they are doing. Try to find a shop that works on performance cars and does performance alignments. Just because they zero toe on Mommy's Camry doesn't mean they know how to dial in a good street set-up.
Old Jun 6, 2007 | 07:36 AM
akunamatta's Avatar
* B A N N E D *
Default Re: ALIGNMENT setting for a lowered daily driver.... (JMelt4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMelt4 &raquo;</TD></TR><TR><TD CLASS="quote">If you are planning on having some random shop play with your camber kit, man, you better pray they know what they are doing. Try to find a shop that works on performance cars and does performance alignments. Just because they zero toe on Mommy's Camry doesn't mean they know how to dial in a good street set-up. </TD></TR></TABLE>
yeah i am taking it to a shop that my bud with an nsx goes when he tweaks his suspension for autox....
i am just looking for specs nothing special guys.... or if someone has an alignment printout of ideal settings for a car....... or atleast, how much camber angle in the font should i have?... how about rear? etc.... if nobody has experience with this the its cool.
Old Jun 6, 2007 | 12:17 PM
JMelt4's Avatar
Do a search. It has been covered many many times. Search for "Camber settings" or "alignment settings"
Old Jun 6, 2007 | 12:34 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
good idea. but then why did you buy the camber kit? Return that. You dont need it. Unless you're doing burn outs, you wont see much camber wear. You might see a tiny little bit if you're just driving with little or no hard turning. But camber is not a big wear angle.
Anyway, it all depends on your suspension setup and what you want to do with the car, so it's an impossible question to answer. But i can approximate:
Camber: either leave it alone to whatever it comes out to being when you lower it....or set the front camber around -2 or -2.5 degrees. Rear camber about the same. That should set up a good daily driver camber angle.
Caster: no option but to leave it alone
Toe: factory
Old Jun 6, 2007 | 12:45 PM
hatchling37's Avatar
Default Re: (B serious)
If you're planning on just rocking a severe negative camber angle, you better be a baller or be content to put **** tires on your car every six months. Camber can really f-up your tires as well as make your car handle unexpectedly on the streets. Granted you won't be pulling any FandTF bullshit (I hope), so the handling issue shouldn't be a big deal.
You should leave the kit on, have a reputable shop align it for you, and tell them to put it to the factory settings. You'll enjoy proper tire wear and your car will handle like it's supposed to.
Old Jun 6, 2007 | 10:08 PM
B serious's Avatar
Default Re: (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">If you're planning on just rocking a severe negative camber angle, you better be a baller or be content to put **** tires on your car every six months. Camber can really f-up your tires as well as make your car handle unexpectedly on the streets. Granted you won't be pulling any FandTF bullshit (I hope), so the handling issue shouldn't be a big deal.
You should leave the kit on, have a reputable shop align it for you, and tell them to put it to the factory settings. You'll enjoy proper tire wear and your car will handle like it's supposed to. </TD></TR></TABLE>
well...you gotta define "severe" though. Severe as in 6 degrees negative? that will wear tires. 2-3 degrees negative wont. A GSR's STOCK settings allow for -2 degrees of camber. Meaning 2 degrees is fine even at a factory level....but it's on the high end of acceptable.
Old Jun 14, 2007 | 08:25 PM
akunamatta's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">good idea. but then why did you buy the camber kit? Return that. You dont need it. Unless you're doing burn outs, you wont see much camber wear. You might see a tiny little bit if you're just driving with little or no hard turning. But camber is not a big wear angle.
Toe: factory</TD></TR></TABLE>
i can aggree with your settings, but im going to search some more
i bought them because my factory ones were stolen... heres a pic (2 months ago pic when found at apartment complex)
Old Jun 14, 2007 | 08:34 PM
oneiro's Avatar
that's some mean camber
nomoshing
Jun 29, 2008 09:20 PM
alleyezonme
Suspension & Brakes
14
Dec 27, 2005 08:17 PM
Kyles ej1
26
Nov 19, 2004 06:09 AM
CrX-To-Tha-Max
Mar 4, 2004 07:17 PM
BADGUYNY
Oct 19, 2003 05:50 PM
