91 hatch starts but will not idle(PLEASE HELP)
Old Jun 3, 2007 | 05:51 AM
johnjohn072002's Avatar
Default 91 hatch starts but will not idle(PLEASE HELP)
the car starts but will not idle need some help does any one have ideas what it could be please help!!
Old Jun 3, 2007 | 08:16 PM
mahatma's Avatar
Default Re: 91 hatch starts but will not idle(PLEASE HELP) (johnjohn072002)
what do you mean? does it stay running?
Old Jun 3, 2007 | 10:28 PM
Default Re: 91 hatch starts but will not idle(PLEASE HELP) (mahatma)
no it shuts off it sounds like a vacum line problem
Old Jun 4, 2007 | 02:52 AM
minime-civic's Avatar
* B A N N E D *
chekc your brake booster vaccuumm line.. [the big *** hose goin to the intake manifold
Old Jun 4, 2007 | 05:00 AM
vdawg559's Avatar
check ur manifold.. seems light something unplug an. if u fix teh problem. say so.
Old Jun 4, 2007 | 05:29 AM
DenzComp's Avatar
Will it stay running if you are pushing on the gas pedal?
Old Jun 7, 2007 | 10:00 AM
Default Re: (DenzComp)
ya it will stay on if i push on the gas
Old Jun 7, 2007 | 10:01 AM
it stays on if i hold down the gas only
89efDUSTY's Avatar
Default Re: (johnjohn072002)
check your idle air adjustment screw, make sure its not closed all the way.
Old Jun 7, 2007 | 10:26 AM
Default Re: (89efDUSTY)
were is that located
Old Jun 7, 2007 | 11:01 AM
DenzComp's Avatar
How old is the dizzy?
Take the cap off and check everything out there.
Old Jun 7, 2007 | 01:03 PM
its all cool
Old Jun 7, 2007 | 01:11 PM
ilikejesus's Avatar
just adjust ur idle on the intake mani and make sure the wire is tight at all
Old Jun 8, 2007 | 07:51 AM
Default Re: (ilikejesus)
its not that
Old Jun 8, 2007 | 08:24 AM
96teggylsse's Avatar
make sure you got all your vacume leaks in the correct place. also check to see if your throtle body is leaking around that gasket. the only thing is sounds like is a vacume leak,just check everything very close. mabe you have a hole in one of your vacume lines also
ballinsk8er
Mar 20, 2007 07:00 PM
red_crx
Dec 5, 2004 01:26 PM
AkumaMax
Mar 14, 2003 08:43 AM
Turbo Powa
Oct 7, 2002 11:58 AM
digitalspice
Feb 20, 2002 02:35 PM
