serious Idle issue.
Old Oct 6, 2002 | 07:36 PM
Turbo Powa's Avatar
Default serious Idle issue.
When I first start the car its starts revving up and down untill it warms up. I have no clue what it may be. Has anyone else had the same problem? What should I check for. Any help will be appreciated.
Old Oct 6, 2002 | 08:10 PM
piatl7il77's Avatar
Default Re: serious Idle issue. (Civic LX 29)
how badly does it go up an down. alot or just a little. mine does it just a little about 50+/-. rpm. If it is alot you may have a vacuum leak.
Old Oct 6, 2002 | 08:13 PM
97hb's Avatar
Check your coolant, might have air bubbles in there. Could also be the iac valve or a leak in the intake manifold.
Old Oct 7, 2002 | 10:32 AM
Turbo Powa's Avatar
Default Re: serious Idle issue. (97hb)
I put some transmission fluid a few weeks ago when this first happened and it went away. Yesterday it came back. How do I check if its a leak in the intake manifold?
Old Oct 7, 2002 | 11:58 AM
Turbo Powa's Avatar
ttt
blackEGFTW!
10
Apr 13, 2009 01:08 PM
Teknic73
Dec 1, 2003 08:44 PM
AkumaMax
Mar 14, 2003 08:43 AM
CivicSiR7
Jan 17, 2003 08:42 AM
Metal_SOL
Nov 25, 2002 06:09 PM
