Clocking center section on a Garrett t3/t4 turbo?
Old May 31, 2007 | 04:02 PM
Tippyman's Avatar
Default Clocking center section on a Garrett t3/t4 turbo?
I successfully clocked my compressor the way that I wanted, but when I tried to clock the center section to get the oil drain correct, it wouldn't budge.
All the bolts came loose no problem, do I need to remove them?
Old May 31, 2007 | 04:10 PM
Boostfed's Avatar
New User
Did you loosen the bolts from the center housing to the turbine housing? If so then tap it with a hammer to break it loose, is it brand new? If it is it should turn freely.
Old May 31, 2007 | 04:11 PM
josh0407's Avatar
Default Re: Clocking center section on a Garrett t3/t4 turbo? (Tippyman)
Loosen The Bolts On The Hotsideof The Turbo. You Have To Really Wake It To Make It Turn. Well With My I Did At Least. Use A Soft Mallet
Old May 31, 2007 | 04:17 PM
Boostfed's Avatar
New User
Default Re: Clocking center section on a Garrett t3/t4 turbo? (josh0407)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh0407 &raquo;</TD></TR><TR><TD CLASS="quote">Loosen The Bolts On The Hotsideof The Turbo. You Have To Really Wake It To Make It Turn. Well With My I Did At Least. Use A Soft Mallet </TD></TR></TABLE>
That is what I meant to say a MALLET not a hammer, either way softly don't kill the turbo lol
Old May 31, 2007 | 04:18 PM
Tippyman's Avatar
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Did you loosen the bolts from the center housing to the turbine housing? </TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote"> If so then tap it with a hammer to break it loose, is it brand new? If it is it should turn freely. </TD></TR></TABLE>
It's not new, it's used. But, there's not a whole lot of miles on it.
So just loosen the bolts, then whack the center section with a mallet?
Old May 31, 2007 | 04:32 PM
DrivinVtec's Avatar
whats clocking your turbo?
Old May 31, 2007 | 05:06 PM
Boostfed's Avatar
New User
Default Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">whats clocking your turbo?</TD></TR></TABLE>
You ain't never COLD CLOCKED someone and knocked them out?
Old May 31, 2007 | 06:47 PM
DrivinVtec's Avatar
huh? lol
whats going? You remmeber me with NA b20 vtec crx I sold to shad? Im George
Old May 31, 2007 | 06:50 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">huh? lol
whats going? You remmeber me with NA b20 vtec crx I sold to shad? Im George</TD></TR></TABLE>
Yeah I noticed when I saw your Avatar with your old car, I knew it was you. lol
Old May 31, 2007 | 07:08 PM
DrivinVtec's Avatar
hehe..whats going on
Old Jun 1, 2007 | 07:16 AM
josh0407's Avatar
yes hit the center section of the turbo
Old Jun 1, 2007 | 07:44 AM
agrn93ls's Avatar
Default Re: (josh0407)
i would brace one side of the turbo either the turbine or compressor in a vice or if turbo is mounted to manifold loosen the bolts to turbine and use whatever housing that is not mounted/secure to use as leverage to turn the CHRA. the CHRA is small so it may be hard to hit with a "hammering device" lol.
Old Jun 1, 2007 | 02:53 PM
DrivinVtec's Avatar
so what does this do?
g2turbo
Jul 9, 2007 09:15 AM
mnlude
Mar 7, 2006 10:22 AM
pro547
Jun 20, 2005 12:54 PM
delslo93
Jan 23, 2005 12:31 PM
slowdx
Sep 28, 2004 08:08 AM
