Tire fitment on Rims
Old May 30, 2007 | 03:16 PM
The-Kid's Avatar
Default Tire fitment on Rims
Hi guys. A really quick question. I was talking to my friend and he is getting some new rims. His current rim size is 15X6.5. And his new rims are going to be 15X7. He is going to try to stick with his current tire.
So I was saying, if you do autocross or any high speed turns, your rims would touch the ground due to radial tires and how they freely move. Am I right or wrong? I'm 50% because its only .5 difference.
Old May 30, 2007 | 08:16 PM
JimBlake's Avatar
Default Re: Tire fitment on Rims (The-Kid)
Only 1/2 inch difference, it should be OK.
Knowing the actual tire size (since you didn't tell us) you can check on tirerack.com for the allowable range of rim width for any particular size.
Old May 30, 2007 | 08:19 PM
The-Kid's Avatar
Default Re: Tire fitment on Rims (JimBlake)
O my bad his original tire size is 195/55/15. It is on his Fit. and he's replacing it with some rims which are 15X7.
Old May 31, 2007 | 06:34 AM
Dren's Avatar
Those tires are a little narrow for a 7" wide rim, but will be fine.
Old May 31, 2007 | 07:05 AM
TheMuffinMan's Avatar
He knows where you live!
Well street tires aren't really meant for AutoX but I just did it on mine and did fine.
Just pump them up a couple PSI higher and he should be ok.
Old May 31, 2007 | 10:20 AM
Cannon Man's Avatar
I have a similar question. I wanna move from my current 18x7.5 wheels to 18x8 wheels. Will my 215/40 be able to handle it?
Old May 31, 2007 | 12:28 PM
Charri's Avatar
Default Re: (Cannon Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cannon Man &raquo;</TD></TR><TR><TD CLASS="quote">I have a similar question. I wanna move from my current 18x7.5 wheels to 18x8 wheels. Will my 215/40 be able to handle it?</TD></TR></TABLE>
you would be stretching the tires a pretty good amount you might notice a slight loss in traction though
Old May 31, 2007 | 01:07 PM
Cannon Man's Avatar
I was thinking since I have a 40 series that I may have a little leeway. They have rounded shoulders because they're falkens, does that make any difference with the fit?
iCollectStraws
May 21, 2009 05:06 AM
janz3n
Apr 5, 2006 08:44 AM
Elmojo
Aug 13, 2004 10:20 AM
USDMMARK
Apr 16, 2003 06:12 AM
Leimokei
Sep 27, 2002 12:27 PM
