how do i run the......
Old May 27, 2007 | 01:32 PM
killafred187's Avatar
Default how do i run the......
fan wires so wen i turn on my car the fan turns on automaticaly ???????
Old May 27, 2007 | 01:47 PM
garageEF's Avatar
Default Re: how do i run the...... (killafred187)
why would you do that? does your fan not turn on at all?
Old May 27, 2007 | 01:48 PM
no it doesnt not even wen its over heating
Old May 27, 2007 | 01:51 PM
cr-x-91's Avatar
did u bypass it to c if it even turns on?
Old May 27, 2007 | 01:53 PM
(noob) wtf is that???
Old May 27, 2007 | 01:54 PM
cr-x-91's Avatar
like give it derect power.....to c if its ur fan thats bad.
Old May 27, 2007 | 01:55 PM
ok ima do that rie now sit tight
Old May 27, 2007 | 02:03 PM
cr-x-91's Avatar
also could be the fan switch on the back of the block..
Old May 27, 2007 | 02:04 PM
garageEF's Avatar
Default Re: (cr-x-91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 &raquo;</TD></TR><TR><TD CLASS="quote">also could be the fan switch on the back of the block..</TD></TR></TABLE>
thats what i was thinking...not an easy job for a noob though....
Old May 27, 2007 | 02:06 PM
cr-x-91's Avatar
x2
Old May 27, 2007 | 02:16 PM
sorry it took so long but the fan does work so wat else could it be??
Old May 27, 2007 | 02:18 PM
garageEF's Avatar
Old May 27, 2007 | 02:19 PM
crap!! how do i switch it??
Old May 27, 2007 | 02:25 PM
cr-x-91's Avatar
https://honda-tech.com/zerothread?id=558328
Old May 27, 2007 | 02:27 PM
alright thanks man!!!!
cr-x-91's Avatar
good info on how it works..no too hard to diagnose urself...good luck man.
Old May 27, 2007 | 03:32 PM
mikejr83's Avatar
I wouldn't run it 100% of the time. The ******* that I bought my CRX from did that. It ran really cool. You don't want the engine running cool. The only time the fan really should run is when you're sitting in traffic. I would check you sensor on the back of the block to see if it is working correctly. Make sure it's plugged up correctly. Also check that the relay at the fan is good; that it isn't full of water, that it is plugged in correctly, and that it actually works (clicks on). Also, check the wire connections from the fan to the harness and the wires to and from the sensor to the harness/ecu.
Even if you call yourself a noob these are not hard things. They are time consuming, yes, but nothing you cannot do. You might want a jack to get under the car and look at the sensor on the back of the block, but you can check it from the top.
Good luck!
Mike
Old May 27, 2007 | 04:04 PM
Default Re: (mikejr83)
thanks man but ill doall these things tomorrow caue i gotta go sum were ill just use ma moms car!! thanks again!!!
Old May 27, 2007 | 08:55 PM
Default Re: (killafred187)
yea thanks to evry one i found out wat it was (kinda stupid) it didint have a relay !!
still thanks every 1
AaronJ
Aug 1, 2007 09:50 AM
lrcrx90
10
Apr 10, 2007 01:44 PM
mike93eh2
13
Feb 17, 2007 04:23 PM
ViXoN Hatch94
Feb 4, 2006 07:53 PM
bon3
Jun 21, 2005 06:00 PM
