how to install heat wrap properly?
Old May 23, 2007 | 08:11 AM
delsol revolution's Avatar
Default how to install heat wrap properly?
I just bought Thermotec heat wrap for my DC 4-1 headers yesterday and wanting to know how to install it properly. i know you need straps to secure it. Also, i got Thermo Tec Heavy-Duty Spray Adhesive. Do you put the heat wrap on your header and then spray on the adhesive or spray it on or spray it on before you put it on your header and strap it down?
If anyone has put heat wrap on their car before any suggestions would help. Thanks
Old May 23, 2007 | 09:34 AM
mike1114's Avatar
Default Re: how to install heat wrap properly? (delsol revolution)
just wrap it on and then use hose clamps or buy the metal things they sell for header wrap and then spray it once its wrapped. Soak that **** good then your good to go.
Old May 23, 2007 | 09:40 AM
B16b-EJ8's Avatar
Default Re: how to install heat wrap properly? (mike1114)
Also make sure you have a good overlap. Meaning if the wrap it let say 2" wide make sure each time around you have at least .5" of overlap.
Old May 23, 2007 | 09:59 AM
94typeR's Avatar
good idea to wrap twice???
and btw, make sure its stainless steel, dont wrap mild steel
Old May 23, 2007 | 10:00 AM
Eran's Avatar
HT White Ops
Are you doing this on ceramic or stainless headers?
Old May 23, 2007 | 05:50 PM
Default Re: (Eran)
stainless headers
Old May 23, 2007 | 05:52 PM
thanks a lot for the help i really appreciate it
Old May 23, 2007 | 06:08 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
i believe you;re supposed to pull it tight too, or else it will get undone easily
Old May 28, 2007 | 12:03 PM
ezza's Avatar
Default Re: how to install heat wrap properly? (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR &raquo;</TD></TR><TR><TD CLASS="quote">good idea to wrap twice???
and btw, make sure its stainless steel, dont wrap mild steel</TD></TR></TABLE>
like an oem mani, i want to wrap my oem h22 mani
RallyRedGT-V6
May 11, 2004 02:13 PM
GCEX
10
Aug 4, 2003 01:07 PM
rockwilda
Jun 20, 2002 06:09 PM
TurbothisLS
Mar 26, 2002 11:19 AM
GSR2001
Feb 22, 2002 09:09 PM
