Axle / CV Joint clicking! and its NEW...Help...
Old May 23, 2007 | 01:54 AM
o VALTER o's Avatar
Default Axle / CV Joint clicking! and its NEW...Help...
Hey, I just got my driver-side axle replaced for my b18c1, it was clicking before, so i got a new one, and installed it. Now, there is more clicking than before. i turn slight right, clicking, all the way right, loud clicking, slight left, not much, all the way, lots. I have a Y80 Trans, and put a 92 Integra CV Axle in, any suggestions on how I can fix the clicking.
Old May 23, 2007 | 03:24 AM
ham's Avatar
ham
Default Re: Axle / CV Joint clicking! and its NEW...Help... (o VALTER o)
is it from autozone? if it is, then thats probably why.
was the car in a front end collision?
Old May 23, 2007 | 04:18 AM
o VALTER o's Avatar
Default Re: Axle / CV Joint clicking! and its NEW...Help... (ham)
nah, from an acura parts dealer...oem i suppose... anyway, that didn't help me fix anything.
Old May 23, 2007 | 09:20 AM
ham's Avatar
ham
couple possibilities that i can think of:
car was hit in the front and the alignment of the motor to the knuckles is off. ive seen this problem on a friends car.
maybe you changed the wrong axle? are you sure it was coming from the driver side CV? ive seen people change the wrong axle before.
the reman axle could also be bad. also happens frequently.
Old May 23, 2007 | 12:05 PM
o VALTER o's Avatar
well, do you think a front wheel alignment would help? suspension and axles have been changed, and I have not gotten an alignment done yet.
Old May 23, 2007 | 01:31 PM
IT GUY's Avatar
are you running a half shaft from a 90-93 integra or from a 94+ integra?
gotta use the DA halfshaft for those axles... alot of times people forget that they are different from the DC's.. using a DC halfshaft one axle will fit fine and the other will be loose.. This could cause the driver's side to wear quickly or almost immediatly
Old May 23, 2007 | 02:05 PM
o VALTER o's Avatar
Default Re: Axle / CV Joint clicking! and its NEW...Help... (IT GUY)
i am not positive, all I know is that when the part was ordered, it was for a 92 integra, is this something I can do as far as putting the car up on a lift, and trying to fix it myself, or should i find out everything about the axle, and see if i need a new one? I didn't put this axle on because my father had the car for a day, and he had everything that I had wrong with the car (breaks, ball joint for drivers side, axle) fixed. So....i don't have a good idea of what is going on. probably should get my **** straight and post it. maybe tomorrow.
wu tang
14
Dec 17, 2007 09:23 AM
tunerkid7
Honda Civic (2001 - 2005)
Jul 12, 2007 11:12 AM
DC2SIR-G
Feb 26, 2006 06:13 PM
Rocks
Jun 28, 2004 11:06 AM
technine
11
Dec 20, 2002 08:42 PM
