wiring up knock on b16 in a 92 cx
well i am now crossing over to the dark side of boost and would like to hook up my knock sensor just for safety perposes. i have a brand new oem knock sensor for my b16 but my question is, how and where do i wire the knock to. is it 1 or 2 wire? does anyone know which pin to wire the knock to the ecu for and what color are the wires?
what ECU are you running?
i cant remember how much the pinouts differ, if they do, between each other.
regardless, its a red/blue wire. and if i remember correctly, pin 6 of plug C.
can anyone verify?
Modified by 94hatchling at 11:45 PM 5/22/2007
can anyone verify?
ok i was a little off.... i did some research to double check myself.
your knock sensor is wired to pin D3.
i was on the right harness plug, just the wrong pin.
and just in case.... this is the pin the KS goes to on the D ecu plug....
D1 D3 D5 etc..
D2 D4 D6 etc..
D1 D3 D5 etc..
D2 D4 D6 etc..
