How To: Wire 99-00 OEM Fog Lights /w Parking Lights
Old May 22, 2007 | 07:49 AM
amej8's Avatar
Default How To: Wire 99-00 OEM Fog Lights /w Parking Lights
<FONT SIZE="3">***5/24 EDIT***
VIDEO ADDED AT BOTTOM OF POST
</FONT>
***I TAKE NO CREDIT FOR THIS WRITE-UP!! THIS IS MERELY A RE-WRITE OF A PREVIOUS HOW-TO***
I know someone has a How-To on here but the pictures don't work. And the other How-To's are outside this forum. So I figured it was in the best interest that H-T has it's own How-To for this again.
This How-To will show you how to wire your 1999-2000 Genuine Raybrig OEM Fog Lights to turn on with parking lights as well as stay on with low/high beams. The fog lights should also work when arming/disarming your alarm when the flashers come on (as long as the switch is on).
Also, this procedure MAY work with 96-98 Genuine OEM Fog Lights but the wires may be different. Should you choose to attempt it, feel free to add in the color of the wires you switched around when you get it to work .
<u>You will need the following:</u>
- Small jewelers flathead screwdriver
- Regular screwdriver to remove underdash plastic pieces
- 10A mini fuse
- 15-30 minutes of your time
<u>Additional notes before we begin:</u>
- The previous How-To recommended to disconnect the negative terminal on the battery since you'll be dealing with electrical stuff. However, I didn't and did NOT run into any problems. Should you choose to is up to you.
- Please keep in mind you CAN do this before actually installing the fog lights. But in order to ensure you did it properly, they obviously must be installed. <u>This How-To was written with the fog lights already installed!!!</u>
- I do NOT take any responsibility for mistakes or problems you run into after completing this How-To! If you have any questions, don't hesitate to ask and I (or anyone else) shall do my/their best to help out.
- Please remember read the additional/comments at the bottom after all the steps!
Step #1:
Remove the plastic underdash piece underneath the steering wheel as well as the steering wheel column cover. Keep in mind that you will have to tug a bit to remove the underdash piece and to be careful when remove the steering wheel column cover. The clips tend to break very easily. Now in order to remove the 2 plastic pieces, you will need to remove the screws circled in red in the picture below:
Step #2:
With the 2 plastic pieces off, remove the 2 white plugs circled in red in the picture below (there are little tabs you have to push in, in order to pull them out):
Step #3:
Unwrap the black tape around the wires between the 2 plugs.
Step #4:
Now use the small flathead jewelers screwdriver and carefully unclip both ends of the red and white wire from each plug (it is also the only wire holding the 2 plugs to the rest of the harness). You should have the following when you are finished:
Step #5:
Again, using the small flathead jewelers screwdriver, carefully unclip both ends of the red and green wire from each plug. I am holding the wire with my thumb and pointer finger in the following picture:
Step #6:
Then continue to take the red and green wire you just removed and put it in the slots where the red and white wire originally were.
Step #7:
Then take the red and white wire you removed in the beginning and put them into the slots where the red and green wire were.
Stop and take a moment to think:
Basically, you are swapping the red and white wire and the red and green wire.
Step #8
Now go to your underdash fuse box and look for the taillight fuse. It should be a 7.5A fuse. Replace that with a 10A fuse.
Step #9:
Plug the white plugs back into the steering wheel column and give it a test. The fog lights should now work with parking lights as well with low beams and even high beams!
Step #10:
If all is well, reassemble the underdash pieces and enjoy .
<u>Additional Notes/Comments:</u>
- BEWARE! In my research previous to doing this How-To, some people have found that when arming/disarming their alarm with the fog light switch on, they have blown their instrument/cluster fuse. I previously noted before I began this How-To that when arming/disarming your alarm with the fog light switch on, the fog lights WILL blink as well when the corner lights blink.
<u>VIDEO:</u>
Sorry I didn't do it at night time. But it wouldn't have made a difference anyways lol. As long as you see it in action which you see it perfectly in this video. May be a tad bit of sun glare but doesn't effect what you see. Enjoy .
Modified by amej8 at 1:37 PM 5/24/2007
Old May 22, 2007 | 08:19 AM
SiShane's Avatar
Default Re: How To: Wire 99-00 OEM Fog Lights /w Parking Lights (amej8)
thanks for the writeup.... or re write up..good **** man!
Old May 22, 2007 | 08:41 AM
amej8's Avatar
Thanks .
I had the chance to test it out last night and it works great. I have Osram Super H3's in my fogs so I can almost drive without headlights on. And highbeams + fogs = t3h awesomeness. I know generally you shouldn't need fog lights with highbeams but it's amazing how much more you actually see.
Old May 23, 2007 | 09:30 AM
amej8's Avatar
Anyone else test this out yet? Just curious because feedback is always appreciated or any questions/comments/concerns.
Old May 24, 2007 | 09:36 AM
amej8's Avatar
Video now added to see it in action.
Old May 24, 2007 | 10:10 AM
Regal's Avatar
Ladies and gentlemen we are floating in space...
Default Re: (amej8)
Awesome with the high beams
Old Jun 3, 2007 | 12:47 PM
Markland Photo's Avatar
i never got aroudn to that lol
Old Jun 3, 2007 | 09:07 PM
amej8's Avatar
I've left my fog light switch on ever since I did this and nothings blown yet *knocks on wood*.
Old Jun 3, 2007 | 11:10 PM
1BOMEK's Avatar
heh, i ghetto rigged it when my switch broke to my corner lights.
i do like it better this way. it looks sick as hell when i turn on/off the alarm. i bunch of other civics ask me how i did it. thumbs up
Old Jun 4, 2007 | 08:59 AM
9civic8's Avatar
Default Re: (1BOMEK)
Hey guys,
I just did this to my car, and everything works great, but... the first time I tried to arm my alarm with the foglight switch set to "ON" the alarm arms, but no flashing parking lights/foglights or tail lights. It also looks like my interior lights are gone too
But the parking lights, foglights, and taillights all turn on when I turn my parking lights and headlights on?
Things I've tried:
I changed the TAILLIGHT fuse to 10amp from the start =
I changed the INSTRUMENT LIGHT/CLUSTER fuse to 10amp =
I switched the foglight switch off and arming the alarm, that didn't help too.
I' am stumped, anymore suggestions? Anyone else with the same problem, I've already looked through this thread:
https://honda-tech.com/zerothread?id=707193 and tried everything suggested there.
Thanks in advance.
Old Jun 4, 2007 | 10:23 AM
SiShane's Avatar
Default Re: (9civic8)
worked like a charm!!!
Old Jun 4, 2007 | 10:37 AM
nyrican23's Avatar
Default Re: (SiShane)
Great write up
Old Jun 4, 2007 | 11:26 AM
6SPD_EK's Avatar
Default Re: (nyrican23)
I did this & my headlights did not work at all I have hi/low HIDs installed
any idea why or how I can redo this & have them work?
edit - oh ****, when I did this from old write up I swap out the red/green completely & did not put the red/green where the red white originally was
time to try again?
Old Jun 4, 2007 | 03:17 PM
amej8's Avatar
Default Re: (6SPD_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6SPD_EK &raquo;</TD></TR><TR><TD CLASS="quote">I did this & my headlights did not work at all I have hi/low HIDs installed
time to try again? </TD></TR></TABLE>
lol you have to swap the wires .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civic8 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
Things I've tried:
Thanks in advance. </TD></TR></TABLE>
Sounds like you maybe switched around the wrong wires or didn't plug something back in?
Thanks for all the other comments .
Old Jun 5, 2007 | 08:59 AM
9civic8's Avatar
Default Re: (amej8)
All the wires are correct, actually when I drove home from work last night, all my interior lights do work, just that the parking lights, tail lights and foglights don't flash when I arm and disarm my alarm.
Any other suggestions guys?
Old Jun 5, 2007 | 09:24 AM
00ekcoupe's Avatar
Great write up. I will give this a try when I get home later this evening.
Old Jun 5, 2007 | 10:20 AM
hYbRiD EeEkAy's Avatar
Default Re: How To: Wire 99-00 OEM Fog Lights /w Parking Lights (00ekcoupe)
definitely trying this out tommorow. been trying to figure out how to do this forever
Old Jun 6, 2007 | 04:02 AM
6SPD_EK's Avatar
tried again & they work - i can't believe I missed that step the 1st time
Old Jun 6, 2007 | 06:32 AM
LsHoney84's Avatar
we hooked up the 99-00 Raybrig fogs to my brothers car normally and we can turn on the foglights with the parking lights.
Did we screw something up? We didnt have to do this
Old Jun 6, 2007 | 06:48 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (LsHoney84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 &raquo;</TD></TR><TR><TD CLASS="quote">we hooked up the 99-00 Raybrig fogs to my brothers car normally and we can turn on the foglights with the parking lights.
Did we screw something up? We didnt have to do this</TD></TR></TABLE>
Yeah, you hooked something up wrong... From the factory they should only come on with the headlights.
Old Jun 6, 2007 | 06:51 AM
6SPD_EK's Avatar
Default Re: (White Smoke)
that ^ or you are not running an OEM harness
Old Jun 6, 2007 | 10:17 AM
00ekcoupe's Avatar
I tried this last night and had similar problems to what 9civic8 had. I followed the exact instructions in the write up.
When I first tested the fogs they worked fine, but later on when I disarmed my car I noticed the parking lights (now w/ fogs) didn't flash like normal. Then when I got in the car and drove all the dash lights were out. I checked the fuse and it was not blown. So I switched out the instrument panel 7.5A fuse for a 10A one and it fixed the problem.
So for those that are having problems... try replacing the instrument panel fuse w/ a 10A one also. So basically I replaced the tailight fuse as well as the dash fuse w/ 10A.
Hope this hels.
Old Jun 6, 2007 | 10:28 AM
Default Re: (00ekcoupe)
everything works like a charm. dash lights are still going great on the 7.5A fuse but if they go out ill change the fuse out. thanks for the awesome write up!
Old Jun 6, 2007 | 10:46 AM
amej8's Avatar
Yes the fuse is a crucial step. Some may not experience problems while others clearly have.
So it's safe to say that you should change the fuse either way.
Thanks for all the feedback guys and am glad you enjoy it as do I!
Old Jun 7, 2007 | 07:32 AM
first day the parking and fog lights worked with the alarm. 2nd day.. no more. looks like i gotta go get me some 10A fuses.
