trany help Plz!!!!
How do i feel up the tranny fliud in my 93 si hydro trans?
can anyone tell me were i can fill it up at and what tool ill need and what kinda fliud to put into it?
HT rules ty.
HT rules ty.
there is a 3/4 inch bolt ath goes in on the side of the trans. you need to take that out and fill it with 10w30 motor oil. i would use castoral gtx.
easiest way i've done it is fill the fluid through the speed sensor...its the easiest way. Just make sure when you take that bolt out (10mm bolt i believe) make sure you hold the speed sensor and plastic piece steady, or else the plastic piece which is connected to the speed sensor and bolt snaps. if that plastic piece snaps, your fucked and will have to buy a new one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaron_morris »</TD></TR><TR><TD CLASS="quote">there is a 3/4 inch bolt ath goes in on the side of the trans. you need to take that out and fill it with 10w30 motor oil. i would use castoral gtx.</TD></TR></TABLE>
you can do it this way but it gets a little messy, going throug the speed sensor is the easiest route.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sihatchy »</TD></TR><TR><TD CLASS="quote">well i work at autozone so speed sensor is cheap... but how do i know if i need any my trans grinds alittle when i go from gear to gear.</TD></TR></TABLE>
you mean how do you know if your low on tranny fluids? if thats your question, the only way i know how to check for it is taking out the speed sensor and checking the oil level from there.
if you think you need more tranny oil, might as well throw in some new oil bro. Since you work at autozone, getting oil is basically free for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sihatchy »</TD></TR><TR><TD CLASS="quote">yea that what i was planing i just didnt know how to do it ty for all ur help bro.
n/p...i was in the same boat once
</TD></TR></TABLE>n/p...i was in the same boat once
stuck_in_the90s
Aug 19, 2009 04:22 PM
Honda_ThuGZ
10
Mar 31, 2008 08:25 PM
d4rksid3
Jun 21, 2007 06:36 PM
