Quick Question
Quick Question
Did a search....but now im confused...
I just want to do a simple tranny fluid change, I found the drain bolt at the bottom of the tranny but cant figure where or which bolt is the fill hole???.....some threads say its on the top of the tranny, I gotta unskrew a speed sensor and some other threads say its a bolt toward the back by the firewall but theres like 10 bolts what size or kind of bolt am I looking for???...I got a D16z6, your help is appreciated and if you got a picture of the actual fill hole that would even better!!! TNX!
Re: (BlackDeLSoL)
Not too sure about the D but on my B there are two hole, one drain and one fill. The fill should be higher up so it shouldn't be too hard to figure out. If you are seeing the two on the side just go with those. Not sure about the sensor though.
Good luck .
Good luck .
I know where the fill hole is but i dont know which bolt/plug it is since theres like 10 bolts mounting the tranny onto the engine....just wanna see a pic of the exact plug to unbolt or the size and type off bolt it is.
Re: Quick Question (KoNiGs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoNiGs »</TD></TR><TR><TD CLASS="quote">Im looking too buy a v-tec controller for my civic
anyone can help </TD></TR></TABLE>
Go make your own thread buddy
Re: Quick Question (BlackDeLSoL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDeLSoL »</TD></TR><TR><TD CLASS="quote">Go make your own thread buddy</TD></TR></TABLE>
that's a complete jack lol
Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">it uses a square fitting not a socket like the rest, i think its just a 1/2" ratchet</TD></TR></TABLE>
just went and checked the fill bolts in the back and there arent any square fitting bolts...only square fitting bolt I saw was the drain plug =/
Mackenzie
12
10-30-2004 07:49 PM
asubennett
08-21-2003 05:14 PM
