speed sensor malfuntion.
Old May 21, 2007 | 01:59 PM
NOman0608's Avatar
Default speed sensor malfuntion.
ever since the swap,
i been gettin the speed sensor malfunction.. i disconnect speed sensor, and plugged it back in and still gettin the code.
any help would be appreciated.
Old May 21, 2007 | 11:02 PM
BlueIntegraBoy's Avatar
Default Re: speed sensor malfuntion. (NOman0608)
Perhaps it needs to be replaced
Old May 21, 2007 | 11:12 PM
aaron_morris's Avatar
Default Re: speed sensor malfuntion. (BlueIntegraBoy)
there are plastic pieces that go inside of the little harness that you could try tot kae out and then plug back in for a better connection. clean them up a bit to.
Old May 21, 2007 | 11:27 PM
Jagolas's Avatar
Default Re: speed sensor malfuntion. (aaron_morris)
what kind of swap did you do?
Old May 25, 2007 | 06:55 AM
Default Re: speed sensor malfuntion. (jagolas)
my car was a auto 1.5 and i threw a LS swap in it. it is now a manual.
Old May 25, 2007 | 07:12 AM
THC07's Avatar
be sure to check the inside of the plug. just last month i was having this problem, turns out that one of the pins inside the harness plug was streatched and not making a connection.
Old May 26, 2007 | 05:19 PM
Jagolas's Avatar
which ecu are you using?
dohc_profile
Mar 3, 2009 05:42 AM
burningrock
Aug 5, 2008 07:09 AM
latindc2
Jul 13, 2006 08:44 PM
CivicVX94
Aug 7, 2005 08:22 AM
