Too weak of a wastegate spring for my boost levels??
Old May 19, 2007 | 02:20 PM
sohc_turd's Avatar
Default Too weak of a wastegate spring for my boost levels??
I'm currently running the Large Yellow spring, which is .7bar (11.6psi) spring, and running 25psi. At about 19-20 psi the boost starts to bounce and fluctuate +/- 5psi really fast and then finally levels off at 25psi in the upper rpms.
Initially i thought it might be compressor surge, but now i suspect it might be the wastegate spring. Ive actually got a 1bar spring ordered on the way, but i would like to know/confirm the symptoms from anyone with similar experience.
thanks!
Old May 20, 2007 | 10:23 AM
boosted k20's Avatar
Default Re: Too weak of a wastegate spring for my boost levels?? (sohc_turd)
what boost controller r u running? that could be ur problem
Old May 20, 2007 | 04:19 PM
sohc_turd's Avatar
Default Re: Too weak of a wastegate spring for my boost levels?? (boosted k20)
I'm running the turboxs dual stage. Whats everyone else using for 20+ psi thats not a EBC??
I'm not a big fan of EBC controlers, i just want to set it and forget about it.
Old May 20, 2007 | 04:34 PM
Jared's Avatar
what turbo/engine? i've run 20+ on 7psi springs with the turboxs
Old May 20, 2007 | 06:04 PM
MidwestAutoWorks's Avatar
what size wastegate?
Old May 20, 2007 | 07:24 PM
sohc_turd's Avatar
Default Re: Too weak of a wastegate spring for my boost levels?? (MidwestAutoWorks)
The setup is sohc/vitara, short tubular manifold, t3/t4 50trim, tial 38.
more info about the setup in the sig.
RACEPAK
Sep 27, 2014 02:57 PM
2LiterTurboSeR
Aug 25, 2005 11:04 PM
dunkd
Feb 3, 2005 11:45 AM
1 POINT 8
Jan 13, 2004 04:16 PM
Talon12bp
Nov 12, 2003 05:05 AM
