Compression Tester hot/cold fitment
Old May 16, 2007 | 11:42 PM
vinuneuro's Avatar
Default Compression Tester hot/cold fitment
Should there be a difference? I just got a compression tester from Harbor Freight the other day. It so happend that the engine was hot when I was testing...tester screwed right in no problem. Later, I wanted to double check..engine happend to be cold...the tester just wouldn't thread up in the plug hole. Does the head expand that much? Is the $5 tester from harborfreight that bad...should I even take the readings I got seriously?
Old May 17, 2007 | 08:00 AM
vinuneuro's Avatar
Default Re: Compression Tester hot/cold fitment (vinuneuro)
bump
Old May 19, 2007 | 11:50 AM
FlatBrokeHatch's Avatar
I've never seen that problem before...it should screw in just fine. Did you try the same plug hole? One could be fine but the other could have messed up threads or something.
Old May 19, 2007 | 12:47 PM
vinuneuro's Avatar
Default Re: Compression Tester hot/cold fitment (FlatBrokeHatch)
All four worked fine with the motor hot. All 4 won't work at all with motor cold.
Old May 19, 2007 | 04:46 PM
DonF's Avatar
The bad news is you get what you paid for. For $5.00 I am suprised you got all 4 cylinders. I hear Snap-On is a good company.
Old May 19, 2007 | 08:51 PM
vinuneuro's Avatar
Default Re: Compression Tester hot/cold fitment (DonF)
I've heard the same . While that would be nice, what is a decent brand for a low-income college student just trying to maintain the car he's got? Actron, Matco, etc perhaps?
juanb
Jul 16, 2007 08:45 AM
NegativeXero
11
Aug 18, 2006 06:52 PM
ilikebigbutts
May 23, 2006 03:45 AM
tek_civic
Aug 17, 2003 04:58 PM
EARLdaSQUIRREL
Jul 12, 2003 06:17 PM
