did compression check, ran into big problem
Old Jun 1, 2003 | 12:38 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default did compression check, ran into big problem
well i did the compression on my new si i just got, and when i was done i was goin to put the plugs back in and the number one plug would screw in good, but not as far down as the others, so im thinking what the F*** so i got a flashlight look down in there and theres my problem, the damn compression piece was stuck down on the end( the lil extension that comes with the kit, i thought it was off but i guess it wasnt) so anyways, i try and fit a socket down in there to get it out, i tried a 5/8 (spark plug socket) and its not big enough , but yet i cant fit an 11/16 down in the hole to get it out, what should i do???how do i get it out, i already tried to screw the compression checker on to screw it back out but it wont
Old Jun 1, 2003 | 12:40 PM
.RJ's Avatar
.RJ
Default Re: did compression check, ran into big problem (coptzer)
needle nose pliers, turn it out
edit: or use a socket thats the same size as the ID of the compression fitting
Old Jun 1, 2003 | 01:04 PM
BluntMan's Avatar
put theadlock on the compression tester and screw it back on and then wait a few hours.
Old Jun 1, 2003 | 01:13 PM
g2 GS-Argh's Avatar
Default Re: did compression check, ran into big problem (BluntMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluntMan &raquo;</TD></TR><TR><TD CLASS="quote">put theadlock on the compression tester and screw it back on and then wait a few hours.</TD></TR></TABLE>Yup, and then grab some pliers and some muscle to get the fitting back off the tester. Same thing happened to a buddy of mine.
Old Jun 1, 2003 | 05:46 PM
hybrid_KJ's Avatar
Default Re: did compression check, ran into big problem (g2 GS-Argh)
This also happened to me too. I used thread lock and it came right out.
Old Jun 1, 2003 | 06:05 PM
irev210's Avatar
Default Re: did compression check, ran into big problem (hybrid_KJ)
same thing happend to me
Old Jun 1, 2003 | 08:21 PM
Default Re: did compression check, ran into big problem (irev210)
damn, makes me feel alot better now that i see more ppl have done it i will get some tomorrow and try it out
Old Jun 1, 2003 | 08:50 PM
piscorpio's Avatar
I did the same thing, I nearly **** myself when I couldn't get it out. I just jammed a screwdriver into the center of the extension and lodged it in there good enough to twist out.
Old Jul 11, 2003 | 10:38 PM
irev210's Avatar
Default Re: did compression check, ran into big problem (piscorpio)
everyones done it, dont feel bad
Old Jul 12, 2003 | 01:13 AM
yea i have talked to a couple of people who have done it, by the way i used red loc tite and it did the trick the first time
Old Jul 12, 2003 | 11:20 AM
blah13's Avatar
Default Re: (coptzer)
Afer I did it I learned to rub a small ammout of oil on the threads before is put the tester in, I agree on threadlock.
Old Jul 12, 2003 | 12:53 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">everyones done it, dont feel bad
Not everyone.
Old Jul 12, 2003 | 01:51 PM
dfoxengr's Avatar
not I. lol i read the directions that said "do not tighten a lot into the spark plug hole" well, something like that. it doesnt need to be really tight.
Old Jul 12, 2003 | 01:53 PM
blah13's Avatar
Default Re: did compression check, ran into big problem (hybridvteceg)
Treat it like an oil filter...once it gets snug, 1/4 - 1/2 turn.
Old Jul 12, 2003 | 06:17 PM
Ryan C's Avatar
Default Re: did compression check, ran into big problem (blah13)
i did it and used epoxy to get it out and just kept it on since then
NegativeXero
11
Aug 18, 2006 06:52 PM
iHOPEyouCHOKE
Apr 21, 2006 06:40 AM
intezn
Nov 4, 2002 06:28 PM
